Front loaders have the door opening actually at the front of the machine, similar to separate dryers so they can both sit side-by-side UNDER such things as kitchen units (as ours are!).
Top loaders obviously have to be in a position for the LID to be opened upwards and therefore could not go under units. These are fine for 'laundry rooms'
There are so many choices of each and it really depends on your own, personal requirements- one is not 'better' than the other I would suggest.
I also understand that some top loaders take bigger loads than fronts- but you would have to check ;-0)
Hope this helps,
John C
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
