Question about Polaroid FLM-3734B 37 in. LCD HDTV
Just curious has the house caught on fire LOL. Thinking of taking the control box off as well and taking a look. bigjob92@hotmail.com
    Problem Solver:
  • 9 Answers
Actually, the tv is still working great.
Posted on Aug 01, 2008
Ours did...did yours? Our insurance company is trying to hold us liable to our deductable since I had a Candle on our mantel. The Candle was no where near the TV. When I found the TV on fire it was coming from the back of the TV.
Posted on Jul 31, 2008
Wj manual transmission gear box
4wd ????????????
WJ jeep
Y2K jeep, must be doomed with Y2k , LOL
the car was sold usa with AX5 box
or NV3550 box.
sticks, which one do you have, in a pallet.
it will take many things to make work.
flywheel , bell housing, box, drive shafts, (more if 4wd)
and wiring changes, and the fire wall clutch pedals, and MC for slave .
and mount changes.
why not just buy a car with a stick and save a fortune.
ive done many cars to switch trans, and its no easy job.
why not just read the jeep.com pages and see all parts unique to the box.
even changes to PCM .
The car will fail smog took, because the PCM will BAARRF vast dtc errors and set you fail smog , in 1 second flat the CEL glowing.
its not trivial at all.
why do this, like punishment,/?
Oct 09, 2016 | 2000 Jeep Grand Cherokee
I turn on power button. Short time later 20 amp breaker trips. I can reset breaker and do a load of wash. Must repeat for each load. I replaced receptacle and 20 amp breaker. Same results
Please do not do another load of wash until this problem is fixed, or you may find yourself with a house/apartment fire!
I am thinking your motor (most likely) or the controls (least) have a short, and are causing your problem.
Oh, yes.
Take a really good look at the circuit breaker box inside, because a broken or loose ground wire ( there are two) can also cause this problem.
One ground wire should be white, one should be bare.
Each should be securely screwed into the lugs of the grounded section of the circuit breaker box.
God bless your efforts.
Jan 12, 2016 | LG WM Washing Machines
Last nigh my Maytag dishwasher model # MDB7100Aww serial # 15666931YM caught fire. Luckily I heard it and was able to put the fire out before my house caught fire. Has there been a recall on this model...
Yes, there was a product recall for your Dishwasher due to fire hazard. Please visit the following pages for further information:
https://repair.maytag.com/repair/dishwasher.jsp?siteCd=MT_EN_US
https://repair.maytag.com/repair/dish_faq.jsp?siteCd=MT_EN_US
The list includes model numbers beginning MDB7 with serial numbers ending in YM, so yours is one of the units affected.
With regard to repair / replacement / compensation, Maytag state the following:
Remedy: Consumers should immediately stop using these dishwashers, disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire. Contact Maytag for either a free in-home repair, or a $75 cash back reimbursement following the purchase of a new Maytag®, Jenn-Air®, Whirlpool® or KitchenAid® dishwasher. Consumers should not return the dishwasher to the retailer where it was purchased, as retailers are not prepared to take units back.
Consumer Contact: For more information, contact Maytag Corporation at (800) 675-0535 anytime, or visit the firm's Web site at www.repair.maytag.com.
Hope this helps - I would advise phoning them on the number above to find out what your exact position is as this recall was issued in 2007. However, there should not be any time limitations on claims and this still appears to be an active recall. They have admitted the dishwashers are dangerous and thereby accepted liability.
Regards,
BElectric
Dec 09, 2010 | Dishwashers
My tv caught on fire what am i needing to do & i need a customer service phone number!!!!!!!!!!!!
If the tv has literally caught on fire then there's nothing more that can be done to save it - just junk it before it burns your house down. If it's still in the warranty period take it back immediately and make a refund request.
Aug 06, 2010 | TruTech Televison & Video
Grill fire
Check to see if the flexible tubes from the burner assembly to the gas valves are clear, undamaged, and completely seated on the burner valve orifices. If these tubes are only partially seated at the valves, gas can leak and ignite under the control panel. If this happens, the control valves can be damaged creating a serious fire hazard. If in doubt, replace the control valves.
Jul 03, 2009 | Grilling
The black box under drivers seat caught fire
Hello, nothing to my knowledge is factory. After market music AMP or security system? Any markings remaining on box? Perhaps followings wire down to where it goes could be of help. Does the car still run okay?
Dec 21, 2008 | 1992 Ford Escort 4 Door
Refrigerator caught on fire.
tough call but. the entire start relay kit and cap can be replaced. it is usually surrounded by metal and if it does fail is not a major source of concern as far as a fire. stink yes, but nothing around it to flame up and cause a major fire. performance can be checked immediately after parts are replaced, and if it starts ok then you are as safe as you would be with a brand new unit if it had the same problem!good luck
Dec 07, 2008 | Maytag MSD2756G Side by Side Refrigerator
start relays smoking is a common fault and does not usually indicate a fault elsewhere. parts are reasonable cost so give it a try
Sep 25, 2008 | Refrigerators
Polaroid FLM-3734B 37 in. LCD HDTV Logo
41 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
