Try to uninstall the audio driver and restart your PC manually, and install the driver again.If the problem is same follow the second,
Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties-window)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers
and others are not in Questioned Mark (?) symbol with yellow color. If
there need to install the drivers).
Or
You can roll back the driver.Follow the bellow link.
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx
Or
If same as before can restore the system. Follow the bellow link.
For Win 7
http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
For XP
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the problem is same , reset your BIOS SETUP.
Please follow the instruction bellow.
Restart
Press Del/F2/F10 right after starting the computer for BIOS setup.Follow the bellow link.
http://www.computerhope.com/help/phoenixa.htm
Just enable on board audio device. If you think it is difficult, set it default or load fail save default.
I always suggest to set load
fail save default >F 10(F key)>yes. Now install the driver again.
I
If the problem is same is before please,use an USB audio device.Follow the bellow link and its not expensive.
http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5
Hope this helps.
If you need more information, reply me soon.
Thanks
