Question about Carrier 38CKC036 Air Conditioner
Carrier Synergy 2000 Condenser fan does not turn on
I have a Synergy2000 system, which had been off for a year. Turned it on, ran fine for a week, now the condenser fan won't turn on, The fan blade spins with virtually no resistance. Compressor kicks on, then off, after fuse is inserted. I presume it is the fan motor capacitor, or the motor itself. How can I determine which, and is there anyplace to get the capacitor model before I take it apart? The system was installed in 1995.
  • 182 Answers
The mfd is stamped on the side of the capacitor.Be careful to kill the power and to NOT touch the terminals.The capacitor is capable of holding a charge even after power is disconnected.
Posted on Jul 29, 2008
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Air con runs for 5 mins then stops, unit outside still going
ok depending on what part of the world your in and the season . Winter: most split systems are designed around a set given temperature of operation , if this is a heating problem the what you are experiencing is the system going into deforest . bare in mind that those carrier splits are manufactured in china and are designed for about 35 deg C in summer and +5 in winter , anything out of this temp range will cause this , especially if it is running on freon 22 , in-which case it sounds like its short of gas to me . if its a new R410 a system , then check your filters and if they are clean and its still doing the same then it too is short , in each case a refrigeration mechanic is required.
May 11, 2009 | Carrier 36KCARMS Air Conditioner
Magic chef fridge RB193A
Which fan is working or are all fans working, condenser clean, hear compressor running ? Let me know.
Apr 22, 2009 | Magic Chef Refrigerators
The fan on my Carrier cental air system is on, and I can't
If your fan selector, NOT SYSTEM SELECTOR, is in the auto position then your fan motor module is likely bad.
Nov 28, 2017 | Heating & Cooling
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Nissan 2000 ac hot when idle
the a/c condenser has a fan in front ( there is actually 2 fans if you sit on the car it will be fan on right side ) if this fan does not
come on immediately when you are parked and engine in idle
there is a problem with power to it, or motor failure. If you drive it
on the highway and a/c operates fine that's because air is circulating though condenser (thats what the fan is supposed to do at idle or slow traffic)
Aug 17, 2008 | 2000 Nissan Maxima
Carrier 38CKC036 Air Conditioner Logo
345 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
