I'm trying to hook up a PC Monitor to a DVD Player. 15 pin on the monitor and component and HDMI options on the DVD Player. What adapter / cable do I need? Thanks, Paul
  • 12,061 Answers
I would try Ebay .. sounds like ya need a DB15 Female to HDMI Male.
OR a DB15 female to DVI male plus a DVI female to component/HDMI
The link below should give ya some idea...
http://search.ebay.com/DB15-Female-male_W0QQcatrefZC6QQdfspZ32QQflocZ1QQfromZR40QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZQ2d1QQsaslcZ2QQssPageNameZRC0021QQ_trksidZp1638Q2em120
Posted on Jul 28, 2008
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
How do I connect a external monitor to my toshiba P55T-B5262 laptop
Ok I looked at the Specs on the laptop --- you have a HDMI port --- Same thing found on almost all tv's now days
-you need a HDMI to VGA or an HDMI to DVI converter --- very inexpensive purchase
Options #1
If the monitor you are trying to has this port:
-then you need a HDMI to VGA adapter
http://www.ebay.com/itm/like/350902230382?lpid=82
Options #2
-then you need a HDMI to DVI cable
http://www.ebay.com/itm/HDMI-to-DVI-D-24-1-Pin-Monitor-Display-Adapter-Cable-Male-Male-HD-HDTV-6-FT-/141210464113
Hope this Helps!
Sep 06, 2014 | Toshiba Satellite Computers & Internet
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
I have a Denon AVR 587 and a Phillips DVD Player. I am trying to figure out how to hook the DVD player up to the receiver without using an HDMI Cable. Also I have a laptop with a DVI connector on it that i...
Get the manuals. All is explained there.
http://www.retrevo.com/support/Denon-AVR-587-Receivers-manual/id/696ci075/t/2/
Component video is just as good as HDMI.
The unnamed Philips DVD player has a manual somewhere. Try retrevo or drill down into this directory to find it...
http://www.p4c.philips.com/files/
Be patient. The alpha directories are slow to load.
DVI connectors can be adapted to HDMI or component video.
"Web search "dvi to component adapter" "dvi to hdmi adapter"
Your PC's video and display controls will determine how all that works.
Aug 04, 2011 | Audio Players & Recorders
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
Do i need a converter box for a samsung syncmaster 940 mw
It depends. What are you using the monitor for? If you want to watch digital TV, you need a digital to analog converter. (It has an NTSC tuner.) Note: the digital to analog converters that were subsidized by the US government coupon only gave SD out.
If you are connecting to a PC, it has DVI-D (21 pin SCART) and VGA connections (15 pin SCART). (An HDMI to DVI cable or adapter would connect to HDMI video cards.) Most other set-top boxes will connect to the component, composite or S-video connectors.
I hope this helps.
Jan 07, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Jul 12, 2010 | Dell Inspiron Mini 10 Notebook
Video Inputs for Denon AVR 589
manual is here: http://www.usa.denon.com/AVR-589-OM-E_006.pdf
Note on page 11 says "because video signals are out put from the AVR-589's monitor output terminal IN THE SAME FORMAT AS THE VIDEO SIGNALS, THE MONITOR OUTPUT TERMINAL SHOULD BE THE SAME TYPE AS THE TERMINAL USED FOR INPUT."
You cannot mix the HDMI with the others. You must therefore use the same on DVD and Cable box.
Best Regards and happy new year!
Charles
Jan 05, 2009 | Audio Players & Recorders
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
I have a sharp aquos hd tv/monitor with rgb and hdmi cable inputs.How do i know if it is compatible with any given pc processor?
Depends on the Computer. Some have a 15 pin on-board video - in which you can buy a 15 pin to HDMI adapter. Others have video cards with DVI outputs - in which you can buy a DVI to HDMI adapter. Or you can buy a video card to supoorts an HDMI output.
Aug 10, 2008 | Sharp Computers & Internet
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
