Question about Vacuums
Hyla electric brush won't work - Vacuums
  • anaiball Apr 09, 2009
    hyla electric brush won't work
Where can I get a Hyla vacuum instruction manual?
Posted on Sep 11, 2010
Need user/owners manual pdf download for Hyla nst vacuum cleaning machine
Go to supececokeso.ga/4538658/62315-hyla-gst-repair-manual-bb342140 You should be able to find what you need.
Oct 14, 2017 | Vacuums
Brushes dont turn
If you are referring to the two main brushes underneath the Roomba (not the side-sweeper) then there are a couple possibilites:
1. The gears need to be cleaned/regreased inside the brush unit. There are several videos/guides online that will show you haw to dissassemble the gears, clean out the gunk, and reassemble. Basically there are four screws that hold the unit in; once it is removed you will see several screws on the side of the unit that contain the gears for the brushes. Dirt/dust/hair makes it's way into the gear-case and gums up the works, which seizes the motor.
2. Another possibility is that the electric motor that drives the brushes needs tp be cleaned or replaced. My Roomba had lint/hair caught up in the electric motor...in fact the dirt was separating the brushes from contacting the rotor inside the motor, which means they weren't cunducting electricity. Once I cleaned out the motor itself, the brushed worked right away! There are a couple view holes on the sides of the motor...get a flashlight and look inside...there is probably lots of junk keeping the motor from working properly.
Apr 17, 2014 | iRobot Roomba 530 Robotic Vacuum
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
581 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
