Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Channel change My current channel is set at 6 on my Linksys WUSB54GSC wireless adapter im hopin to change it to 11 but i cant find out how to do it can somebody help me
Go to device manager...under network adapters, click your device, then enter the advance settings-look for channel
Posted on Jul 29, 2008
  • 12,061 Answers
OK this is usually only done at the initial install... Un-install it completely, then reinstall and when it starts fill in the Country and Channel.. should be all good... There also may be a Utility, check Linksys web site, that comes with/for the device that will allow you to change it on the fly as it were.
Posted on Jul 28, 2008
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
Linksys compact wirelless G USB adapter model noWUSB54GC wersion1 a cant find driver for windows7
The driver for windows xp should be compatible with windows 7, Try to install it that way if it doesn't work call Linksys tech support 18003267114
Jan 16, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Why doesn't my Wireless G USB Adapter (version3) work with Windows 7?
What is the exact model number of your wireless adapter?
You may refer to this link for a compatible list of devices with Windows 7.
Also, please refer to this link on how to manually install the drivers.
If you are using the WUSB54GC v3, this will work with Win 7 using the Windows Vista driver.
Below are drivers that you may download from the Linksys website for WUSB54GC v3.
Windows 7 Driver 11/09/2009 Ver.3.00.01(32-bit)Windows 7 Driver 09/11/2009 Ver.3.00.01 (64-bit)
Hope this helps! Good luck!
Jan 02, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Change the channel
• access rtrs gateway, default is 192.168.1.1
• click on wireless tab
• wireless channel === dropw down arrow, select 11
• save settings
>>>> just make sure that while making this changes your laptop or dsktop is hardwired to any of the numbered ports of the router
Oct 23, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
