The screen can be replaced. It's expensive though. Luckily, someone on Craigslist is giving away the same model that you have. It isn't working. It's in Detroit. Their number is 313-920-6540. I hope this helps.
If your TV is anything like mine (which I expect it is, since they’re the same brand), all you have to do is use a T-20 screwdriver bit to remove all the screws from the back of the frame around the plexiglass. Once the screws are out, the frame just pops up and the plexiglass is easily removable.
By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
