Laars Lite 2 pool heater will not fire. Pilot is on and I replaced the pressure switch. Had a similar problem at the start of the season but left on for a few hours it finally kicked in.Water pressure in system is good.Filter has been cleaned and backwashed several times.Not sure how to check switch and temp. setting dial. Thanks M.M.
    Scholar:
  • 104 Answers
I believe that the Laars Lite 2 heaters are a millivolt system . There is a thermopile in the pilot assembly that produces about 500 millivolts DC. This is the power that the gas valve uses to turn on. These pool heaters are notorious for getting resistive connections that restrict the flow of electricity through the circuit. A connection that looses 1/4 volt is no big deal with 110v but in a millivolt system that is half of your power. Start by checking the output of the thermopile then go through the entire circuit and clean every connection with sandpaper. usually this will fix it but if not then you will need to isolate each individual component to find out what is not passing power.
Good Luck,
Chillmaster
Posted on Jul 29, 2008
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2 pilot stays lit but burner will not fire
make sure pressure switch tube is not plugged see if both sides of pressure switch have 500 milliamps make sure gas is on
May 20, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
My pilot light is lit but the heater won't turn on.
GET A NEW PRESSURE SWITCH.. CALL AND ASK FOR A PRESSURE SWITCH FOR SAY A HAYWARD POOL HEATER .. LOOKS LIKE THIS ..EBAY Pressure Switch Hayward generic pool heaters also H100
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Though the pilot lite is on the heater burners won't come on. We had very bad storms the past few days and I wonder if that affected the heater in any way. Is it the pressure switchor there's a little...
try bypassing pressure switch, if htr fires,it is either faulty or out of adjustment.storm should have no effect on a millivolt heater unless it took a direct lightening hit. let me know how if it works out
Aug 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
