Question about SanDisk Sansa e250 MP3 Player
I need help
Whats the website so i can get it fixed
mine broke but luckily just the outside
but i nrrd to fix it cause i can hardly see anything
  • 8,596 Answers
Go to google, type in Sandisk
Posted on Aug 14, 2008
My Cuisinart food processor has model #DLC-8F; I would like a new blade mine is cracked.
"fixya" neither has nor sells any parts for anything.
We are a website offering information on fixing things in and outside of the house.
Please type your request into the computer search engine, and you should find a Cuisinart dealer who will help you.
God bless your efforts.
Jan 23, 2017 | Cuisinart Food Processors
My Neon Dodge (1996), experiencing hard starting,most often times in the Morning when i about to start,it will take too much time (around 30 minutes) before it starts, until such time the battery getting...
If a car doesn't start normally there could be 3 main causes:
1.No spark (check spark plugs and distributor for wear end aging)
2.No fuel (check the fuel filter(if a fuel come out dark from it - change the filter, fuel pump (for wear), fuses(for burns))
3.No air (check the air filter)
If this doesn't help take it to professionals. Hope this helps
Jul 13, 2011 | Dodge Neon Cars & Trucks
Can not find a site to register my new trimmer i will just return the product and my some thing else you donot nrrd my email you need to have a site that is user frindly
Don't know how you got here, but we sell nothing except advice...on how to fix stuff.
Check for the correct website of your trimmer...so you can register it...
What make and model trimmer do you have??
heatman101
May 11, 2011 | Garden
I own Bose system Lifestyle 28. my remote control does not work at a distance. if go 4 to 6 inches from the system it takes the command. what is wrong with my system/control system? My remote control...
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
It is hard to take apart... I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose. It is an easy fix if you know how to solder.
Sep 26, 2010 | Bose Lifestyle 28 System
The freezer is freezing up in the back, on the in side.
The place where its freezing (i.e. the inside), & on one side, the cooling coil could be bent if any receptacle big enough to dent the inside, had been pushed too hard. causing the den,t Basically the insulation used in today's freezer technology is PUFF, which heats up the outside of the body (of the fridge) & degrades quickly to a conductible material and could have caused a short, which luckily didn't happen to you. Get the insulation fixed at that end & ensure that the outer & inner patches are sealed to the normal air(air-tight) like the rest of the body..........................sodeep
Sep 18, 2009 | Refrigerators
Wondering where the exterior sencor is located for the outside temperature on a 1998 oldsmobile intrigue?
Location is behind the plastic air dam that forces air from underneath the car to go up and into the radiator (directly in front of a/c condensor). It's somewhat of a tight space, however you can pull it with force off the plastic air dam it's connected to (about midway down) and then unclip the sensor from the harness. Just don't pull too hard once you free it from the plastic air dam. These sensors rarely need replacing. If your Dual Digital Climate Control System is giving you an incorrect reading on the display for the outside air temperature, this indicates a couple of possibilities. 1.)The sensor tip is dirty and should be cleaned, or 2.)The green or white wire that goes to this sensor is worn or has broke somewhere before the sensor. This happened to mine (green wire broke) and would always give an incorrect outside air temp. I fixed the green wire and now the system functions correctly again.
Sep 06, 2009 | 1998 Oldsmobile Intrigue
My dell DJ has a harddisk problem, or so it tells me. It is stuck in recovery mode, even when I reset it. The 'Clean Up' option pulls up a window that says 'Scan Disk..." but then just returns to the menu....
Try to see if you can upgrade the firmware...mine did this so i upgraded to the latest firmware from Dells website. It actually had the upgrade already- but it formatted the drive & fixed the problem. Luckily i keep a file backup on my pc so i didnt lose anything with the format. It worked for me, so it might be worth a try for ya; if it doesnt- well ... i found several 20 gb DJ2s on line for like 50 bucks. would problably cost you more than that to fix the one that you have- just a thought
Feb 02, 2009 | Dell DJ MP3 Player
My screen broke on my garmin wide screen - i have a warranty 1 year manufacturer and a 4 year best buy and they wont cover it. . . what do I do?
Contact Garmin www.garmin.com. Make sure its registered with them and explain what happened. They have a flat rate charge to fix anything for one price but you need to see if they will cover it under the warranty. Physical damage is hard to prove as a factory defect, unless it was that way out of the box.
Best Buy loves to sell warranties that they won't honor. They're credit card system is a joke and their phone reps are outsourced outside of the US.
Sep 15, 2008 | Garmin GPS
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
