Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
Digital Lifestyle TV, 32inch, FA 1B32ZD
I have my tv hooked up using cablevision. The color bounced in and out, now it is permanent blue, brown & yellow. I called digital lifestyle and they suggest I use the HDMI Cable. With the HDMI Cable I get a great picture but no sound. ( I did buy a new cable ) but have the same problem. If you have a solution I would love to hear it. Could you please send a solution to valeriewarren@optimum.net I happen to come across this website using google. If you know of a excellent repair service in brooklyn, please send it also.
Thanks
    Scholar:
  • 141 Answers
Some systems will not transmit audio with HDMI. Obviously this is the case with your system. In this case, you will need to run audio between your cable box adn your TV. The best is digital or optical audio, otherwise just use RCA cables from audio out of the cable box to audio in on the SAME channel as your HDMI is connected.
Posted on Sep 06, 2008
When I hook up DVD player to 32inch LG television there is no color on the TV it plays in black and white. Why?
first check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green)
then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
Mar 22, 2015 | LG 32LD450 32 In. LCD HDTV
I have a cablevision box with a set of red, green and blue wires and another set of red and white wires. How do I hook the cable to tv to get cable? The colors on the front and back of the Mickey tv are...
hi. The colored cord you described are for high definition, there should also be some jacks on the back of the cablevision box that say "video out" "left""right"
Find those, and the video out is the yellow in jack on Mickey, and the Left is the white jack on Mickey
If you can't find those, then use the cable tv out from the box to hook it up to your tv.
This is all that is needed to hook up really, just the coax cable from the box to Mickey.
I know Mickey has a antenna cable jack on the back.
Just run a cable from the box to mickey, put Mickey on channel 3, or 4, depending on what the setting is on the box, and you should be good to go!
Feb 08, 2011 | Disney DT1300-C 13" TV
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
My TV does not display the color red after hooking it up to the Dish Network box. Also the color green looks brown.
If you are using the Component RCA video connectors (RED, BLUE, GREEN) make sure they are correctly attached at both ends.
Nov 05, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Picture will not come on but sound does
It can be the backlight inverter board is bad or the power supply is not supplying power to the inverter board.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Don't know how to connect wii
Use these cables, matching the colors, to hook up the Wii to the TV, then change the input using the remote control
Jul 24, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
I'm trying to hook my PS2 up to my Digital Lifestyle tv. When I hook up the PS2, I can get a black and white image, but I can't get sound or color...
You may be connecting your PS2 with a different cable connection than you used previously.  If this is the case, reconnect the PS2 to the last television that it worked on and change the video connection settings to what your next television is using.  Then power the PS2 down and move it to the next television.  The picture should be fine now.
Jun 06, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
TV COLOR WENT BROWN IN COLOR
It could not be the playstation that would cause the fault. The set was probably going to fail anyways.
A brown casted picture sounds like there is a loss of the blue colour drive in the set.
Some TV sets have colour temperature adjustments in the user menu. Check to see if your TV has that option, and that the colour temperature is properly set up. You can refer to the TV's instruction booklet for details.
A loss of blue drive can be from failed components in the video path, or in the bias circuits that control the CRT's cathold current.
It is also possible that the CRT is going defective, and is losing emission from the blue colour electron-gun.
You will have to bring the set to a service center that has an experienced TV tech who can make proper diagnostics, and give you an estimate for the cost of repair.
Jerry G.
Apr 29, 2008 | Philips 55PP9352 55" Projection Television
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
120 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Back2life...
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
