Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony dp26648 tv
My picture looks too squatty
whould like know how i can i adjust it for
a normal picture
  • 125 Answers
I would like to help you but I do not know what squatty is
Posted on Aug 06, 2008
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Apr 04, 2012 | Sanyo DP26648 LCD TV
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
Apr 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Sanyo DP26648-R 26 in. LCD TV
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Pictures and icons look squatty How do I make them look normal?
change your resolution. depending on whether its a widescreen or not, this can make pictures look squatty. if its widescreen, generally 1400x900 is a good resolution. on regular ones 1280x1024 is generally good. but that also depends on what size ur screen is also
Jul 30, 2009 | Computers & Internet
I have an Orion TVD 2710. Need to adjust resolution.
if you have a menu button on tv shoul be able to do it there after you push the menu button then use the up or down button for selection then the volume up or down to ajust then menu to exit. Now if no menu button sometimes you can push the up down chanel button at the same time and get into the menu. Hope one of these works.
Feb 20, 2009 | Orion STV2763 27" TV
Picture looks stretched, people are squatty looking
You may only need to change the format for the picture. Check your owners manual for how to change the picture format, or aspect ratio. The tv may be in the zoom mode the way you describe it. There is likely an option in the menu to allow the unit to automatically set the format based opon the signal being received. Only some of the programming you see is actually HD. The Super Bowl was broadcast in HD and has a 16:9 aspect ratio (width to height). When this set is adjusted for a correct HD display I'm confident you will be impressed. So I believe this is a matter of a customer setup with the remote. If I had the unit in front of me I could offer more detail. I hope my general opinion helps.
Feb 02, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Jan 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
