Question about Cuisinart DGB-600 Coffee Maker
When I turn it on to grind and brew, it doesn't do anything, just a continuously beep until I turn it off
  • Anonymous Aug 06, 2008
    the coffee maker continues to beep...it will not start. I have tried closing the top to make sure it hits the button on top of the grinder cover as suggested on line but it will not work and just keeps beeping..Help! coffee maker DGB-300
  • 515 Answers
Make sure everything is fitted in place.
Posted on Aug 11, 2008
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My DGB-700BC cuisinart coffee maker grinds beans but then gets stuck and will not continue brew cycle. keeps beeping. please help!!!
We bought our Cuisinart 12 cup grind n brew less than a year ago. Almost as soon as we started using it we began having problems with it hanging up between the grinding and brewing cycles. It would sit and click. I tinkered with it incessantly and usually could, after fiddling long enough with the filter lid, get it to brew, but it was aggravating, to say the least.
When one morning it would NOT work I called Cuisinart and was relieved to hear that there is apparently a problem with some of the filter lids not seating properly. They are sending us a new one. The rep I spoke with told me that if this did not work they would replace the unit, so at least it sounds like their customer service may be on the ball.
So, call Cuisinart for a replacement of your filter lid and see if that solves your problem.
May 12, 2010 | Cuisinart Grind Brew DGB700 12Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder won't stop
Hi
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I just purchased a dgb 550 series 2 days ago, I was moving it and it is now making a beeping sound and will not allow me to do anything, I have unplugged it and replugged and it still does this I tried to...
The constant beeping means that something is out of place - make sure the charcoal water filter holder is in place, even if there are no filters inside. Make sure the grind chamber and all parts are in place. Make sure the filter basket is in place, and that the door is closed. Finally, make sure the lid of the coffee maker tiself is shut and that the lid of the craffe is firmly in place. If everything is in place, it should stop beeping. Turn the coffeemaker off, and then on after all of this is done.
Mar 08, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-600 Coffee Maker Logo
78 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
