Question about Datacard Group Datacard SP75 Color Card Printer (Duplex, IAT MAG, 100 Card Input Hopper, Lamination Lock and Ethern...
The LCD screen show a message "Error Duplex"
Hello!, my name is Edward, iam from Venezuela. The printer show this message on the lcd screen and i can't print. I read the manual but i can´t solve the problem. Thanks for you help!
my name is ramdani,iam from indonesia. first solution is we need chek cable power,cable usb and etc .ok thank.....
Posted on Sep 29, 2010
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Dell 3000n printer rotate error
Hi There
You select wrong page that's way the error is showing. Select the correct supporting paper setting.
Dec 28, 2011 | Dell 3010cn Laser Printer
Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
Hi Edward
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
User tries to print double-sided but only the first page goes into the duplex unit and the printer says Processing duplex job but nothing else happens [except the odd clunk]. Switching off printer clears...
The error you have seems to be a memory error. Try some of the suggestions listed <a href="">here</a>
Dec 14, 2009 | Office Equipment & Supplies
5500 color cartridge replace error
Hello sir,
What number error message is it showing on the lcd and does it show up when you try to fax?
Dec 11, 2008 | Kodak 5500 ALL-IN-ONE PRINTER
"Unable to..." error message appears on the LCD and I can't do anything further
Could you plz:
1. name your printer manufacturer and model name?
2. What error code does the display show?
plz write it down without quoting!
Apr 15, 2008 | Office Equipment & Supplies
LG L1930B 19" LCD Monitor Problem... HELP
When an LCD Monitor starts to respond like this it is due to one of three reasons a power supply is not generating enough power to properly power the LCD or the LCD's backlight is beginning to burnout, and last the inverter is bad. These things all can be replaced, but it is not worth the cost! Easier and cheaper to buy a new one!
Nov 25, 2007 | LG L1930B 19" LCD Monitor
Hello Emilio, it seems that your camera was in contact with water or Coca-Cola. In order to repair it you should change light guide plate part number: 147913011 or LCD part number: 180572011 or both. Best regards, Arpi
Apr 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Datacard Group Datacard SP75 Color Card Printer (Duplex, IAT MAG, 100 Card Input Hopper, Lamination Lock and Ethern... Logo
125 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
