Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
I need help finding where I can purchase part # 930B921002 for Mitsubishi DLP Projection TV Model # WD-62525. Any assistance would be much appreciated. Thanks
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Posted on Jul 29, 2008
My Mitsubishi Projection TV Model WD-62525 screen has pinkish lines running through the screen. The lamp has been replaced. What could it be?
not the lamp. Its a known issue with the power supply. Bad capacitors usually. this requires a servicer to repair it.
Sep 17, 2015 | Mitsubishi WD Televison & Video
I have a WD 62525 tv that will not turn on, completly dead no lights or sound. replaced the main fuse on power supply board what else could it be?
you might need to have voltage checking at this time. if their is a dc output voltages at the power supply board.if none the main board will not turn on.then probably their is bad component at the power supply board.
Nov 18, 2012 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
This is a power board going to the lamp of the DLP MITSUBISHI TV I HAVE THE NEW LAMP BUT THERE NO POWER GOING TO THE LAMP THE TV HAS POWER IT WON'T LIT THE SCREEN
there are bad capacitors on the power supply.
look for bulged caps
they look like this
replace the big ones on the power supply to fix the lamp issue
there are more bad ones inside typically on the dm and fmt boards
they are 1000uf - replace those ones with 680uf @ 16v caps
let me know if i can be of further assistance
Jun 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Source for pico fuses for the Mitsubishi WD-62525 Power Board
Tries Websites Tv repair World.com,Tvrepairkits.com and Ebay.com look for the pico fuses.
Mar 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
How to replace Bad Capacitors on a Mitsubishi WD-62525?
#1 press menu on mitsubishi remote control.If the white round cloud don't go.
you need to replaced block optical......light engine
Sep 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
333 people viewed this question
Top Televison & Video Experts
