Question about Amana Dishwashers
The door handle on my dishwasher is sticking and I can barely open it.
  • 135 Answers
The door latch and handle assembly needs to be replaced. If you have a handy person order the part and replace it....otherwise you may need a service tech
Posted on Jul 28, 2008
How to replace HVAC Blend Door Actuator
By removing the instrument cluster if you look to the right all the way to the back upper corner you can barely see it. looks like a little sliver ball with a black handle sticking out. pushing in the ball handle part will open the front A/C vents, you may even be able to find away to push stick or screwdriver in there to keep it open. Or if you find some specialty tool you might be able to replace it with removing the whole dash board.
Oct 27, 2013 | 1996 Ford Thunderbird LX
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Cant open dishwasher doorany hints?
In order to release the latch mechanism you need to either get inside the door or you need to get to the top of the cabinet of the dishwasher. The screws that hold your dishwasher into the cabinet are up under the lip of the cabinet. The door may be in the way of getting a screwdriver in to get the screws out so that you could slide the dishwasher forward to see the latch on top of the case of the dishwasher. You might be able to get a right angel screwdriver into the space between the door and the cabinet and work those screws out. You may have to remove the bottom panel on the dishwasher and screw the legs up a bit in order to pull the dishwasher forward. If you get the dishwasher forward, you may have to disassemble the latch mechanism enough to get the door open. Then comes the problem of figuring out what caused the latch to stick. I hope this will help you resolve your immediate problem
May 12, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
Dishwasher door will not open
You will have to remove the mounting screws holding the dishwasher in place. Then pull the dishwasher out of the space a couple inches.
You can then activate the door catch from the top to open the dishwasher.
Once you have it open,
You will have to open the control panel by removing the 6 screws across the top inside of the door. You can then examine the door latch assembly to find out what part is at fault.
Dec 20, 2009 | Maytag Dishwasher
The handle sticks out too far which prevents me from opening a drawer that is positioned perpendicular to the washer. Any ideas ?
You can try to recess (push it in more) the dishwasher further under the cabinet, so the handle doesn't interfere with your adjacent drawer.
To do this, you'll have to remove the 2 screws that are located at the top of the dishwasher that secures it to the underside of the countertop.
Once you've got the screws out you should be able to slide/push the dishwasher back an inch or more, to allow clearance. It might not look the greatest asthestically, depending on how far you need to push it into the cabinet.
Otherwise, I'm not sure removal of the dishwasher handle is possible, as it's needed to open the door on this model.
Hope you find this Very Helpful and best regards!
Aug 19, 2009 | Miele Premier-Plus Built-in Dishwasher
My built in dishwasher door will no longer stay part way open it went klunk when I left it barely open and now feels like it weights a ton. All the controls are on the to edge and it has a huge handle that...
hi there......you havent stated which tye or model your appliance is...however it sounds like your door spring /suspension cords or cable have broken....on some appliances their replacement is quite simple..however be warned other tyes are quite involved
regards Sir Galahad
Aug 13, 2009 | Kenmore Dishwashers
Indesit DG6100W dishwasher will not work
It sounds as though the micro-switch inside the lock mechanism is displaced.
Undo the 6 screws at the top of the door (on the inside) and remove the outer pane. This will give you access to the lock mechanism. Please switch it off first.
The micro-switch can then be adjusted so that when the handle is released, the switch engages (you should hear a very soft click).
Hope this helps.
Jun 20, 2009 | Dishwashers
Dishwasher latch
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Apr 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Aug 03, 2006 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
174 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
