Question about Gateway MX6920 Notebook
Need a new battery for my gateway laptop computer. thank you
    Scholar:
  • 177 Answers
"Mundo Corp" specializes in Gateway Parts. Google "Mundo Corp."
Also www.getpartsonline.com
Posted on Jul 24, 2009
  • 30 Answers
Ebay is a great place to get 1
Posted on Mar 16, 2009
My gateway 4525 battery is 95% charged but won't tune the computer
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 04, 2012 | Gateway 4525GZ Notebook
Tip
How to reset Gateway Laptops
Unplug your gateway computer, pull the battery out of you computer, Hold the power button down for 60 seconds, it might not take this long, but better safe than have to go back and do it again. Release power button, install battery, plug in ac adapter, then power on. This helps to recognize new batteries and start up problems do to new hardware installations.
on Mar 06, 2010 | Computers & Internet
My wife plugged in her lap top( gateway N58) with my son's plug-in for his notebook, the difference in power is 0.5A/imput ( less for the notebook), same 19 volts,but less output AMPs 1.5A notebook /...
The power receptors next to the battery sound like toast. Try running the computer off of just the charger (correct one) with no battery. If this works, you need a new battery. If this doesn't work, your computer needs a new power supply. Hope this helps =]
Mar 01, 2011 | Gateway Computers & Internet
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
I have had a variety of problems since 2007 a few months after I puchased this gateway laptop from HSN. Big mistake. Customer service for Gateway is terrible! The battery will not charge, screen fails...
Let's think about this. The computer is 3 years old, probably running Vista. It needs a new battery, not surprising on a 3 year old system. The screen doesn't work for some reason.
A battery & screen will run you $150-200. It may still have a problem.
A new computer with Win7 is $400-500.
I know what I would do.
Sep 21, 2010 | Gateway Computers & Internet
We have a gateway laptop model 7405gx and the battery light is blinking even though it is plugged in. Do we need a new battery? What kind is it? thanks. Judy
Does it still work fine on battery?
If you remove the power lead when the battery is in does it shut down.
If so the batery is probably gone.
Replacement bateries are expensive £77 here
http://www.laptopbatteryinc.co.uk/gateway-7405gx-7410-7410gx-battery-p-3238.html
Jul 10, 2010 | Gateway Performance 500 Deluxe PC Desktop
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
you can take the laptop to a laptop shop & have them resolder the power plug to the mother board or purchase a new motherboard.
Jan 16, 2009 | Computers & Internet
I was told by the computer repair company the connection is arching back and shorting out the chargers. To have a connection replaced would be $150 so that is what we are going to do. We have gone through 4 chargers on our gateway also.
Jan 12, 2009 | Gateway MX8711 Notebook
Gateway MX6920 Notebook Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
