Question about Toshiba Satellite A100-S8111TD Notebook
Blank screen sometimes
At stratup, the lcd on my toshiba a-100 often stays blank. The backlights are clearly still on and turn off and on as I close and open the lid.
The machine is posting and booting as I can start windows and hear the startup music.
Here's the strange part... If I start the computer and immediatly close the lid... then watch for the lcd light to come on and open the lid, it works fine. but 19 out of 20 tries to start normally with the lid open and I just get the greyish backlit blank screen.
Any ideas?
    Sergeant:
  • 395 Answers
Can you try an external monitor?
Posted on Aug 05, 2008
Toshiba Satellite P205-S6267 screen is blank but backlight is on and external monitor out works
Your LCD panel needs to be replaced more than likely. There are plenty of youtube videos if you are a DIYer, otherwise take it to your local computer shop and they should be able to fix it up within a day or two for 50-100 dollars plus the cost of the part. Good luck... you can find all your parts on ebay if you decide to go DIY
Mar 23, 2013 | Toshiba Satellite P205-S7402 Notebook
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
When I turn my Toshiba laptop on,it's black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
No picture sometimes
If the screen is still lit up then it's your lcd controller which will cause the screen to just be lit up but blank. If the screen does not stay lit up then it's your backlight inverter(s) in this case you should be able to hold a flashlight up and still see the picture on the screen just very dark.
Aug 22, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Need hep
replace lcd or check for its connectivity from motherboard to lcd
Aug 09, 2008 | Toshiba Satellite M35-S456 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
232 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
