Cannot install operating system on hard drive windows xp.. i can format the drive but the files all load but cannot install..i get the message cannot read the hard drive
    Problem Solver:
  • 21 Answers
There may be a bad sector on. If you are choosing quick format during install, it skips the sector check. Go ahead and do the full NTFS format and see what happens.
Make sure the jumper is set to the correct setting. If it's the only drive on the ribbon, it should be master or CS. (Cable Select)
Posted on Jul 28, 2008
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
I am trying to restore the original software on my computer and I have the discs. When I put the first disc in ''Symantec Ghost'' error comes up and it won't do anything. Any help what to do?
You need to format your drive first. Back up all your documents and then follow the instructions belowl.
nsert the bootable Windows XP installation disc and restart your computer. When you see the message “Press any key to boot from the CD,” press a key to do so.
A blue screen will show up, and the setup program will now load all the required files. This can take a while, so don’t panic; be patient. Press the enter key when you see a message “Press Enter to set up Windows XP.
Now your screen will show all the partitions available on your hard disk. Select the partition where you wish to install Windows XP. Press the D key, and then press the L key to confirm the deletion. Repeat the process for all the partitions that you wish to format/delete.
Now you’ll see “Un-partitioned Space” in place of the list of the partitions. Select this box, and press C key to create a new partition. Now, select the size for the new partition. You’ll now go to the screen that will read something like this: “C: Partition 1.” Select the partition and press the enter key; on the next screen, select the file system to be used to format the drive. You may choose either NTFS or FAT32 file system. Formatting will now begin.
You may need to wait for some minutes as it takes time to format the hard drive. The time required to format the hard drive depends on the processor speed and the size of the hard drive. Once the format procedure is complete, a new screen will show up that will guide you through the installation of Windows XP.
Good luck
Dec 23, 2009 | Microsoft Windows XP Home Edition
How do I go about installing XP when the previous operating system was deleted. Got XP operating system disc, but doesn't load.
Write zeros to the hard drive using the software from the hard drive manufacturer. Then you will be able to format it and install your XP
Oct 21, 2009 | Microsoft Windows XP Professional With...
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Windows xp not installes on hp notebook
It means your hard drive is not connected to the computer. Go into the BIOS and check to make sure it shows up. The best thing, set the BIOS to the default setting.
Feb 21, 2009 | Microsoft Windows XP Professional With...
My hard drive on my acer 2010 died so I was thinking about replacing it. Do I need to do anything special to it before I load the operating system disk, etc.. Will it boot up and give me directions?
You just install the replacement hdd, the operating disk will prompt you to format and partition (if required) (windows xp & vista) once all loaded you wil probably have to load some drivers.
May 18, 2008 | Acer Computers & Internet
Hp Pavilion a1220n -- Copy file errors when Installing windows
Maybe I can help;
When I install a new hard drive I like to re-install the operating system (OS) as well. Unfortunatly this wipes out all your files.
Typically when files do not copy it's either because they're in use or the media (your new hard drive) is not formatted properly.
Note, formatting erases everything on the drive being formatted.
Instruction for this are easy to find online but are all done for you if you use the OS install CD which will walk you through the setup, formatting, and partitioning.
If you have a way to save your files to another drive such as a usb thumb drive, external hard drive, cd or dvd, I would go about it that way. There's usually alot of uneeded files created by the operating system after a period of time and there's no sense in keeping them. They only slow your system down.
One other thing you can consider if you don't have an external hard drive is purchasing a hard drive enclosure for your old hard drive. You can find them at Best Buy. I paid about $30. Its just a case and usb cord you can use as an external hard drive and also copy any files you can still access on this old drive over to your new one.
Let me know if this helps you
Apr 20, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
ACER 4720Z
seems that it's a SATA drive and the drivers are not included in XP.
There are some tools available to include these drivers into the XP CD.
Search the net for 'xp-iso-builder' or 'n-Lite'.
This is not necessary if your laptop's got a floppy drive (i don't think so). Then the SATA drivers can easily be loaded by pressing F6 when booting from the XP CD.
Mar 02, 2008 | Microsoft Windows Vista Ultimate Edition
Uninstall xp
You can remove service pack 2 from within add/remove programmes, you will not lose any documents, but you will lose the udated security patches which is not recommended. If you mean you wish to remove XP SP completely, obviously the files and everything you have installed on c drive will be deleted as you can only save docs etc within an operating system, as c: is just a partition on your hard drive the files reside within the operating system. If you are upgrading to another operating system my advice would be to use a dual boot system and install the other operating system on a seperate partition of your drive, but you would have to have a fair knowledge of pc operating system installation processes.
Oct 03, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
