He2 washer keep flashing f22 error
  • 1 more comment
  • st1957 Oct 26, 2008
    When I push the start button it flashes F22
  • Anonymous Nov 15, 2008
    yes i have the same problem but i have not yet figured out how to fix it
  • Anonymous May 04, 2009
    I have a whirpool front loading washer.not had it but 6 months and didn't use it for about 2 days went to put some clothes in it and it kept sayin F 22 will not start or nothing.
  • 135 Answers
What is the model number and brand?
Posted on Jul 28, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
Washer flashing F22 and dooris locked and will not open. How do you unlock the door to reove the clothes?
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
Sample tech sheet for HE frontloada
Get your tech sheet by removing your bottom panel or posting your model number here
Duet manual and more here
Sep 10, 2010 | Kenmore HE2 Plus Front Load Washer
Error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
I am receiving error codes on my HE 2 plus front loading washer. F33, F22. and it won't get past the 1st cycle. Is the problem the CUC. or is there a quick fix to this problem.
i found this site thought you may find some help here but there seems to be a lot of peeved off people when it comes to this brand lol
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~6621/forum_id_~409
Jun 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
May 05, 2008 | Kenmore 82836 Gas Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
