Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Apple Airport Express not working
Unfortuntely my wireless network, aka airport express just went on the blink while surfing. I contacted my ISP and nothing wrong their end, and in anycase i have the cable connected directly into my macbook.
The express is flashing amber and I have resetted both hard and factory with no joy. When i go into the airport utility, it seems to be the default settings which might be amiss:
"this apple wireless device has default settings. you should configure your apple wireless device to connect to the internet, secure the wireless network and a provide a password"
So, how do I go about reconfiguring the network, or in layman terms, getting the darn thing working again?
All help greatly appreciated.
  • martfoto Mar 27, 2009
    I can configure the express to my time capsule and it shows up but the orange light just flashes away. My powerbook connects to the network wirelessly OK but not the express. I just wanted it to extend the network to a bad reception area but it won't even work next to the base station.I did send an earlier express back as it just stopped working but this is out of warranty. I just guess it's a **** product that does not really last very long.
Throw the device out of the window, the apple folks are terrible and liers they mislead us into buying this device and it is not working with most Vistas.
Posted on Aug 12, 2008
My airport express is showing a blinking orange light but mac still wont discover it
In order for your airport express to work, you have to wait for a green light to appear. I had this problem as well and what I learned was to unplug the airport express for 30 min, reconnect it, and the green light should show after a few minutes of it blinking orange, and you are good to go.
Aug 19, 2010 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
You need to use the AirPort utility, which will walk through the setup and configuration of it. You were already on the right track to get it going. If it mentions there is an update available for it, though, do the update first.
Jul 28, 2008 | Apple AirPort Express with AirTunes...
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Vista compatibility
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Aug 23, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
988 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
