Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge problems my ice maker making ice but its not dispensing though the door also there no water dispensing either. i check water flow from wall to filter and there water there but i pull water line off the bottom of frigerator no water . where can i find the water soloid that feed this?also when the level switch for the ice and water push the light goes dim.
  • 135 Answers
The problem is in your control board...it is a recall from GE....they will cover the repair for free for 3 years from your date of purchase...or 5 years on just the part....if under 3 years call them for warranty repair.....the board is inside a panel on the back wall.
Posted on Jul 28, 2008
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
No water to ice maker.Ice maker quit making ice.
What I found was the problem was that I had not changed the filter on a regular basis.Because of this the water flow to the ice maker was restricted.What this caused was the water inlet tube on the ice maker to freeze up.On my unit it is a black rubber tube about 11/4 long on the right side.You can see it if you know what you are looking for.If you squeeze it you can tell if it is froze or not.You can use a hair drier to thaw it out or squirt water up into the tube .It does not take very long..To make sure it is clear disconnect the tube on the back of the fridge and blow into it.If there is no restriction the tube is clear.After you have determined the tube is clear add water to the ice tray so the unit will make ice this will start the ice maker to cycle.Its making good ice now.
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
65 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
