Question about SanDisk Sansa E280 MP3 Player
E-280 Control Ring
Greetings-The control ring on my son's e280 is inoperable.
Is this something that can be addressed remotely or do I need to send it to be repaired-if so-any suggestions where to send it?
Bill BB
    Problem Solver:
  • 20 Answers
It is most likely unfixable. email sandisk at support@sandisk.com to get a return.
Posted on Aug 03, 2008
Replaced abs traction control sensor on 2006 pontiac torrant when i brake fill's like traction control kick's in right before i come to a complete stop make's a grinding sound or some sort
look on the front axles for the ring with teeth look between the teeth for cracks rust forms behind the ring and the rust expands and cracks the ring the crack then sends the wrong speed signal to the brake module
Sep 02, 2012 | 2006 Pontiac Torrent
How to use the mc-dc2 how many buttons do i push to operate
There's only one button on the MC-DC2. Just plug it into the appropriate jack on the camera. You don't need to change any settings on the camera.
The button on the MC-DC2 now does exactly what the shutter release button on the camera does. The only exception is when the shutter speed is set to bulb. In this case the shutter remains open as long as the button is held down. There's a hold ring around the button on the remote; press the button and slide the ring in the direction of the arrow to hold the button down. Slide the ring in the other direction to close the shutter.
Mar 31, 2011 | Nikon MCDC2 Wired Remote Control for D90...
Group Pickup setup on Strata 280 phone system
Try Googling (Toshiba)(280)(manual) without parens.
Aug 12, 2017 | Toshiba Computers & Internet
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
We have a Cyberpix 26720. The remote control
Remote control for Cyberpix TV Model 26720 Our technical dept. have said that our replacement remote IRC81582 will do for your model the price is £19.93 incl vat and 1st class postage. To purchase one please ring on 01635 278678 or you can send a cheque made payable to :
T.W. Electronics
Beacon House
Winchester Road
Burghclere
Newbury
Berks
RG20 9JZ
Nov 04, 2009 | Televison & Video
Removed an inoperable remote starter, what do I do
I am not sure which wiring diagram you need but I have several on your particular vehicle if you need them. I need your email address to send them. Tell me which one you need, like under the dashboard or what.
Aug 20, 2009 | 1994 Chevrolet C/K 3500
Remote control for my tv
well we are a help and fix site we can only advise you
my advice is to go buy a universal remote or ring the brand of your tv and order a new one
Sep 11, 2008 | Philips 483521837121 Remote Control
Repair Facility for Sansa e280
I think the only repair facility is sending it in to sandisk. if it is still under warrenty, it would be freem however if it is not, contact sandisk at support@sandisk.com.
Jul 10, 2008 | SanDisk Sansa E280 MP3 Player
Hampton Bay Ceilng Fan light support
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at renee.walton@comcast.net.
May 29, 2008 | Universal Remote Control Hampton Bay...
Broken locking ring on Quantaray 28-90mm. 1:3.5-5.6
Hey Quiltzlady,
If you were an authorized service technician you could probably order this part from the manufacturer, and if this camera is really only $90 to purchase new it is very likely the cost of the repair would not be worth doing. The suggestion to super glue the ring back together might work but I would try epoxy being that it is a lot stronger, but remember you run the risk of rendering the lens inoperable when you involve glue with something that relies on moving parts to operate properly. Another suggestion is to find the same lens, but broken, for sale that this ring is not broken on, and use that lens as a parts lens I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 20, 2008 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
SanDisk Sansa E280 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
