Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Same issue Where are the fuses located?
  • alandf Jul 29, 2008
    sorry  convergence and video itself is concave
  • 1,030 Answers
Fuses.. forgive me i see many tv and questions a month ... what fuses are you speaking of. convergence main power
Posted on Jul 29, 2008
My .manual doesn't tell me what fuse is for my power window
Hi. I just looked up your issue in an online manual for your jeep. I could not find it either. However, let me ask you something first. Do the other automatic windows work? If they do then your issue is not a fuse. More than likely your window regulator or window motor is bad. As for you fuse issue, you probably have a secondary fuse panel located inside the vehicle. Open the driver or passenger side door and look at the side of the dash (could be on either side). There should be a removable cover that hides your secondary fuse panel. Remove that cover (most are just plastic) and you may see another fuse panel. Open that panel and the location of the power window fuse will be available. Some of the jeeps I have seen have this secondary fuse panel. If there is not one there then it may be under the dash. I am surprised that the owner's manual does not talk about this fuse panel location. If you do find the fuse there will usually only be one for the power windows. If it is a fuse issue, none of the power windows will work. Window regulators fail routinely. If you have never replaced one, I recommend going onto YouTube and do a search for your vehicle. I am sorry that I could not locate that fuse for you.
Nov 06, 2017 | Jeep Cars & Trucks
Where are electrical fuses located in Audi Q7?
Location of electrical fuses in Audi Q7. There are four places in which fuses are located in your car.
Checking for burned fuses is a first diagnostic step when troubleshooting any issue with electrical or electronic systems.
on Feb 04, 2015 | Audi Q7 Cars & Trucks
Ive got 2008 1.8 petrol Ford Focus titanium with lose of power steering where is power steering fuse found and what number in location in fuse box
If this is a fuse issue it blew for a reason. For location of fuse reference your owner's manual, the info is there. The fuse box I would concentrate on is the one under the hood.
Jul 22, 2016 | Ford Cars & Trucks
Which fuse is the Anti Theft for a 1998 Volkswagen New Beetle?
If you have an owners manual a diagram of the fuses is usually listed there, also, the cover for the fuse box usually has a list of what each fuse covers. You can also go to the link below for a PDF document showing the locations.
Hope this helps.
Jun 14, 2014 | Cars & Trucks
Fuse panel location
the fuse box is located lower dash drivers side ,cover/lid usually has list inside to the fuse locations etc, does the four way switch turn the signal lights on ? if so the fuse for the turn signals is probably the issue , if the four ways don't come on it may be the flaher relay which may be in the interior fuse box but if not the fuse box in the engine compartment is the next place to look, hope this helps
May 24, 2014 | 1987 Oldsmobile Cutlass Salon
Disable ABS without losing brake lights?
Many of the master cylinders have connection for a brake light pressure switch. Some also active the brake lights by placing a switch directly under the brake pedal. You may need to build your own bracket.
Nov 22, 2013 | 2004 Cadillac CTS
When this happens, there are quite a few things that could be the issue, so I would recommend that you check the simplest thing first. Start out by opening the fuse panel and locate the A/C fuse and the FAN/BLOWER fuse (these are separate fuses) make sure that the fuse is in working order, replace with same AMP fuse that is removed. Next I would recommend that you visually inspect the A/C compressor and make sure that the electrical connections are clean and connected, and that the belt is on the compressor and that the compressor pulley is rotating when the engine is running. If that is not the issue, I recommend that you have the A/C refrigerant checked to see if the level is at the operational level. If that is not the issue, there may be an issue with the clutch on the A/C compressor, or even an issue with the A/C switch in the vehicle located on the climate control panel.
I hope that you have found this information to be useful, and if I can be of any further assistance, please let me know. Thank you for using fixya!
Oct 03, 2013 | 2004 Acura MDX
Where will i find the answer for my problem where is the fuse located on f150 ford supercrew 2001 window and moonroof 4 door 5.4
look in your owners manual for fuse block location as well as fuse location what is the issue with these circuits did they stop working ?
Aug 31, 2012 | Cars & Trucks
My 2000 Tpyota Sienna DC power outlets are both not working. What are the possibilities? Fuse -- where is it?
There is a 15 amp fuse that should be located under the driver side dash labeled power outlet. You should check the radio fuse in the same location. It has a 7.5 amp rating. Those two fuses power your relay so if they good check the relay that is in the same location and labeled accessory main relay. If that all that checks out there is junction connection also located under the driver side dash with a blue/black wire on one side and if its a 4 door the other side will have 2 wires one will be red/black and other be white, If its a 5 door both wires will be red/black. Check those for power. If there is no power then you have an issue with you wiring. If there is power then you either need you replace the outlets or there could still be an issue with your wiring some place after the junction box. Hopefully i didn't get to complicated.
Jul 06, 2009 | 2000 Toyota Sienna
Whirlpool oven
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 22, 2009 | Whirlpool GH4155XP Microwave Oven
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
