Question about Whirlpool Kitchen Ranges
Whirpool side by side refrigerator
The freezer is not keeping the ice trays cold,but not freezing and the fridge side is not keeping foods and drinks cold we have thawed it out and found ice builds up on the freezer side so we thaw it out start it up it is fine and than few day later we have the same prob all over again it says it is a no frost fridge so why would ice keep building up is there something we can buy or replace on it that might fix our prob if the ice would not build up it would work fine but we are stuck
  • 135 Answers
The automatic defrost system is malfunctioning causing a frost build up. There are 3 components in the defrost system. A timer, a thermostat, and a heater. The most common to go is the timer. But it would have to be checked by a technician to be sure.
Posted on Jul 28, 2008
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
The food is freezing on the fridge side of my Whirpool Estate model TS25CGXTD.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 15, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kitchen Ranges Logo
199 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
