11 Freeview channels missing. 32" LCD.model code;LE32R51BDX / XEU. type; R32EO. serial; 43763HFY901926E. product name;GNXXEO. software version 1055 firmware; GREEPEU7-1000. hardware; V1.60a. current software; T-GREEPEUO-1055. alternative [old] software; T-GREEPEUO 1034. do I need a PIN for the Reset page ? channels missing from the "Full Guide" 6, 9, 10, 11, 14, 19, 28, 35, 36, 71, 75. in all other respects a cracking good t.v. recommended it to me Mom, she bought one too. Do you believe its a relatively simple reconfiguration that I can do myself ? Hope you can help, thanks, David.
  • curtisschwar Oct 02, 2008
    After autotuning I also have at least channels 1, 2 , 9 and all radio channels missing.  1 & 2 are BBC1 and BBC2 so this is quite a problem!
SOURCE: RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed.
I had the same issue with my RCA DCW615R. First time my ISP Comcast flashed it back to the old version. This time I could not find anyone who new how to do that. I used to have the software and I have searched the net. Seems they provider RCA does not have it.
This time I called Comcast because I noticed that the 192.168.0.1 brought me to their software update. They supplied me with the user name and password. I was able to get into the firmware and change all the settings using the new firmware. I think the only reason they gave it to me is because my printer is a network printer and it would not work unless I could access the firmware.
The old 192.168.100.1 does not work anymore because that was Cable Modem mode or CM mode. The new address 192.168.0.1 does work but you will need the user name and password from your ISP, this is RG mode or residential gateway mode.
Liked the old firmware better but they both do the same thing. Seems the Gateway works better with the new update. Still I would like to find the old firmware not sure why RCA doesn’t have it.
Posted on Jan 07, 2008
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: NEED SIGNAL PANEL FOR SAMSUNG
www.partsstore.com is a certified distributor for samsung just enter the make and model number of your set and it will bring up all the parts they carry. They usually have circuit boards for samsung
Posted on Mar 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: LCD TV SAMSUNG
What is the nature of your request?
Posted on Mar 18, 2008
mattozan
  • 555 Answers
SOURCE: Need Mac G4 laptop schematic manuel
Not sure if you want an actual circuitry schematic, or a internal parts guide.
A manual for field-replacing just about every component inside your Powerbook can be found here.
I expect that circuitry schematics are much harder to come by, and are actually likely to be protected by trade secrets.
Posted on Apr 03, 2008
Which version of Award BIOS supports HT?
I suggest to visit the manufacturer's website. If manufacturer has changed BIOS or Update the BIOS, the patches or new BIOS will be available there.
Jan 25, 2016 | Intel Computers & Internet
What is a freeview board
freeview board is just what it says it is. picks up digital signal from the aerial can be a number of channels in one code.ie analog has one chanel to one code number say 32 on search. on the same code number in digital 32 will have any were for 5 - 20 tv channels on just this one code number it save the channels to the listings.
Oct 02, 2013 | Toshiba 46SL417U LCD TV
I have lost Sky Channel 82 from Freeview on Samsung HD TV I have tried to reinstall but channel 82 is still missing
U have more than one tv?Yes.Tries check on the other tvs see if u have channel 82 freeview channel,freeview channels are take out or add on all the times by the tvs stantions broadcasting listing.If yes channel 82 is on the other tvs.Than u have low or weak antena signal.U have a analoge antena probally correct?Buy and install a digital antena,u will get a stronger longer ranges tvs incomming broadcasting chaanels tvs stations.Rescan for channels again,u will pick up channel 82 if it still on the air.
Aug 11, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Re: Samsung : LE32R73BD
hi yes there is, put the tv in standby, on the remote control press info, menu, mute, power the tv will come on with service menu just select reset,, if this don't work you will need to replace the maniboard thanks
shaun
Mar 22, 2017 | Televison & Video
How do you retune Freeview channel 5 for a Sanyo Digitital TV
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 02, 2009 | Sanyo DP32746 32 in. LCD Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Televison & Video Logo
296 people viewed this question
Top Televison & Video Experts
