Question about Kenmore 24 in. 15953 Built-in Dishwasher
Hit start button and nothing happens
My Kenmore dishwasher will not start. I hit the start button or delayed start button and I get nothing. The other buttons work when pushed. I have done a manual reset and the dishwasher goes through its test cycle fine, has water, the arm spins, etc. After the test cycle I try hitting the start button and nothing happens. I have already changed the inlet water valve and the float switch seems fine. Any suggestions??
  • cturk519 Jul 28, 2008
    I have already looked at the page you suggested. I would like to know if anyone has had a similar problem and a fix or suggestions before spending $180 for new control panel
    Genius:
  • 1,056 Answers
On solid state control panels and components, such as the one in your unit, once they have internal problems they are best repaired by replacement.
That is, unless you are comfortable with doing board level repairs.
Have sectional errors like this (where one part works, and other don't) are fairly common.
It also depends on the age of the unit. If it is a few years old, the chances of it breaking in one area that is commonly used are very likely.
If you have gone through the full diagnostics (which you state you have) the next step it to replace the unit.
Posted on Jul 28, 2008
  • Kenmore Master
  • 19,396 Answers
Try first unplugging power cord for five minutes, to reset settings, if you heep getting the problem, the timer/programmer , or the whole control panel is probably brooken,
in this case you can get replacements here.
  • 13,433 Answers
I hit the delay button for 2 hours yesterday on my kenmore elite front loading washing machine and nothing has happened and the door is locked
unplug it and wait for the machine to reset. You should hear some clicking noises. May take a while for it to reset.
Jun 28, 2014 | Kenmore Elite HE5t Washer
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
May 10, 2014 | Dishwashers
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I have kenmore dishwasher and the clean light is flashing green and nothing else will start.
To reset hit buttons in this order- hi temp, air dry, hi-temp, air dry. All lites will come on. You can then hit cancel. If problem recurs then unit is not washing for some reason. Keep me posted. Please leave feedback.
Nov 28, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Mar 09, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
Aug 23, 2007 | Kenmore 24 in. 16462 / 16464 / 16469...
Kenmore 24 in. 15953 Built-in Dishwasher Logo
344 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
