Question about SanDisk Sansa Clip MP3 Player
Volume my volume is all the way up and wont go down what can i do. I dont want to buy another one
  • Anonymous Jul 30, 2008
    My volume is all the way up too! I can't turn it down.
  • 8,596 Answers
I guess the volume - button is not working?
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
My buttons 4 5 6 and to lower the volume and the down on the ch dont work what do i do
Most likely the remote stopped working , and theirs not much you could do.. Try buying a universal remote from Best Buy , they go for $10
Jul 03, 2011 | Televison & Video
My canon powershot SD280 sound wont work.. The sound turn on Okay, but the Video doesnt = It DID work and i dont know what happen to it !
hey boss- just figured this one out.
while the video is playing, you can increase the volume by pressing the button above the Func. Set center button and decrease the volume by pressing the button below the Func. Set button. Think we both accidentally turned the volume all the way down.
Too bad you can't tell this by going to the volume menu! Would have been nice to know I was still recording audio while shooting video. Hope this helps!
Jan 24, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
Aug 29, 2009 | Sony RM-Y173 Remote Control
MAGNAVOX PR1910 C125
try pushing the up volume button and the down volume button at the same time.
Jan 03, 2009 | Philips 28PW6506 28" TV
Panasonic KXFHD331 something simple the ringer volume was adjusted and somehow it got messed up and now wont receive I dont know what to change
ringer volume can bi adjusted with volume key or with navigator kex by pressing up and down.if fax is not receiving just check fax receive mode .put iton fax only mode.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Mp3 volume button wont work
may be broke, but:
-Tha Mp3 Doctor
Jul 22, 2008 | SanDisk Sansa Clip MP3 Player
VOLUME...............
That's right Ihave the same problem I am not sure if you tried changing profile and set it to out door see if it helps. My phone has some worst problem if I turn the volume up from the volume stripe it wont even work good luck:p
Jul 20, 2008 | T-Mobile Dash Smartphone
Speakers wont turn down
its the audio quality in windows settings. go to the cpanel and change the sound volume in windows sound settings
then change volume. it should work otherwise. there old speakers. try buying a new bose speaker or something.
Jun 01, 2008 | Audio Players & Recorders
SanDisk Sansa Clip MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
