Question about Pioneer Audio Players & Recorders
I HAVE A VSX-401 RECEIVER AND THE LEFT SPEAKER CUTS OUT AT LOW VOLUME. I FIRST ELIMINATED THE SPEAKER. I THEN REPLACED THE REAR SPEAKER TERMINALS AND BALANCE CONTROL AND WOULD HAVE REPLACED THE VOLUME CONTROL, BUT IT WAS UNAVAILABLE. I WOULD APPRECIATE YOUR ASSISTANCE.
  • Devan Wolf Aug 14, 2013
    Try adjusting the balance to the left, that quiets down the right speaker a little.
jeesusfreek
  • 18 Answers
SOURCE: Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Posted on Jan 28, 2008
  • 4234 Answers
SOURCE: Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
Posted on May 08, 2008
SOURCE: Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Posted on Sep 09, 2009
mlapres
  • 757 Answers
SOURCE: Pioneer audio receiver pre-amp output
It is possible then that the root cause may not be electrical, but acoustic if you're noticing the issue from your listening position.
If you can run a channel test signal identically one channel at a time by positioning your meter less than a foot away and exactly the same distance with each speaker and the level differs by more than 1/2dB, then it's not the acoustics.
Posted on Dec 24, 2009
SOURCE: Front speaker (L&R) no volume, please help
I have a VSX-9300s in which the preamp and power-amp are normally linked with short u-shaped connectors, or require RCA plug cables to connect them. If these are missing, no signals can reach the L/R speakers. Check your manual or carefully inspect the rear panel for the preamp outputs and power-amp inputs.
Posted on Jan 29, 2012
REAR SPEAKERS ON PIONEER VSX-401
@Michae Yokeum
"Rear Speakers on Pioneer VSX-401".
Hi Michae.
Wow, nice Hi-Fi!! :) :)
IF [manual_required] THEN
GOTO
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0523.pdf
ELSE
Check your SBch* setting which should be set to ON or AUTO.
*Speaker Back channels
More info on pg. 83 of manual.
PS - as this is a home hi-fi and not a car-radio, I've moved it from 'Cars & Trucks' to a new home 'Audio Players../Pioneer', where experts in that field can offer more help.
Oct 15, 2017 | Pioneer Audio Players & Recorders
Possible overheat
Check for crushed , damaged and shorted speaker wires at the terminals of both the amp and speakers and over the entire length of the wires. Clear any shorted connections and replace damaged wires. If still persisting, you may need to have it serviced.
Apr 19, 2014 | Pioneer VSX-D307 Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Pioneer VSX D903S ...HOW do i adjust the rear speaker volume....it is currently much too low
You make surround channel adjustments using the on-screen GUI interface. This can be done either by using the remote (recommended), or by using the appropriate controls on the receiver. [The GUI mode is active when the GUI button and the ring surrounding the Multi-Jog dial is glowing amber.]
Nov 07, 2011 | Pioneer VSX-D903S Receiver
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
Pioneer vsx 5900s cuts out when turn volume up
most amps do that if too high in volume.but check yr speaker ratings and connections
Jul 04, 2010 | Pioneer VSX-D509S Receiver
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
493 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
