Question about Fuji FinePix Z10fd Digital Camera
How do you operate the 10 second timer ? i know where the button is but how do you activate it to start the 10 second delay ?
  • 489 Answers
After you set the timer (to 10 seconds), you simply aim at the subject and press the shutter button, like you would when taking a picture. The difference is that the picture will be taken only after the 10 seconds has elapsed.... and not immediately ( like if the timer has not been set at 10 seconds).
Posted on Feb 27, 2011
SOURCE:
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Does the FE-340 camera have a time delay feature so that we can take our own picture?
Please look for clock sign on buttons to turn on-off timer function.
Press clock symbol button to turn on timer function, press shutter button to start timer (10 seconds delay) to take picture.
Mar 14, 2010 | Olympus FE-340 Digital Camera
How do I delay a camera shot on the fujifilm finepix j12? I would be extremely grateful anyone knows how to do this, to write me a solution, thanks :)
The self timer mode is set with the down button on the Menu/OK dial.
It looks like a clock set at 10 to 10.
The first press sets it to delay 10 seconds, the second press sets it to delay 2 seconds and the final press turns it off.
To take the picture half press the shutter button to focus then press it all the way to start the timer.
Hope this helps.
Mar 08, 2010 | Cameras
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Timer?
hi... try this method
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
Self-timer icon appears at the bottom of the LCD:
10 seconds—A picture is taken after a 10-second
delay (so you have time to get into the scene).
2 seconds—A picture is taken after a 2-second
delay (for a steady, auto-shutter release on a
tripod).
2 shot—The first picture is taken after a 10-second
delay. A second picture is taken 8 seconds later.
The camera takes the picture/pictures after the delay....
thank u
May 24, 2009 | Polaroid i830 Digital Camera
Delay timer
You can download the manuals for the PowerShot SD600 here.
To use the self timer feature, you need to set it up in the menu first.
1. Press the Menu button. If not in the shooting menu (silhouette of a camera), use the left or right arrow to get there.
2. Use the down arrow to select Self Timer.
3. Use the right arrow to select the clockface with a 2 or a 10 (2 second or 10 second delay).
4. Press the Func./Set button.
5. Press the Menu button to exit.
Once set up, you can activate it by pressing on the down arrow. You should see an icon change from a rectangle to a clockface at the top center of the LCD when the self timer mode is selected. Press the down button again to cancel the self timer mode.
Apr 24, 2008 | Canon PowerShot SD600 Digital Camera
Taking a photo of the family, delaying the camera until I can get into the shot.
Sure, follow these steps...
  • Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
  • Put the camera on a tripod or other tall article
  • Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
  • Press the shutter button all the way down to activate the timer.
    • Press once for ten-second delay
    • Press twice for three-second delay
    • Press a third time to stop the timer
  • Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
Please rate FixYa!, ThankYa!
Dec 15, 2007 | Nikon Coolpix 4500 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
122 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
