Question about Fujitsu Heating & Cooling
Heater not working - Fujitsu Heating & Cooling
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Posted on Jul 29, 2008
My heater has stopped working. I think it's because I placed a t-shirt on top of it and it switched itself off. Will it work again? Or will I need to have it repaired?
more than likely the heater has overheated and has to be repaired/replaced I assume we are talking a portable heater like a space heater? if this is the case then it deffinitely overheated.
Mar 06, 2011 | Heating & Cooling
Hot tub emptied while a way found leak have fixed but heater will not work is this a fuse or what system is a vs500z
The heater works when there is flow through the pump. If the pump is working and the thermal overload switch was reset and still no heater, check all fuses. There may be three or four in the control unit.
Feb 19, 2011 | Heating & Cooling
Water heater isn't making hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Feb 08, 2011 | Heating & Cooling
Ac not working heater blows smoke into car
Is your car using coolant?
I'm not there to see or smell. But most of the time it is steam from a bad heater core.
Please If it is your heater core have it blocked or repaired.
If you run out of coolant you could do severe motor damage. At the same time it may fix your AC.
May 16, 2010 | Heating & Cooling
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
LG split system heater cooler. the heater is not working and fan outside is working
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
1998 gmc envoy heater problem, fan is working fine but is blowing cold air on defrost and heater.
Do you smell antifreeze? If you do, then your heater core needs replacing.
If not then try these solutions:
Priority Action Part Type Cause 1 Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 2 Inspect Thermostat Thermostat stuck closed grey_line.gif 3 Inspect Heater Control Valve Leaking or defective heater control valve.
Jan 19, 2009 | Heating & Cooling
Rheem heater will not work
seems like you have a defective heater.
Jan 21, 2008 | Quasar HQ2052UH Air Conditioner
Heating & Cooling Logo
701 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
