Question about Hotpoint Ultima WF860 Front Load Washer
WF860 error F12
Washing machine was switched off at mains for the first time in a year. When switched back on sreen says F-12 and will not work ! Argh!!!!! I have
3 baskets of smelly beach washing ! Can't find my manual so can any one help please?
    Scholar:
  • 97 Answers
Hiya
i'm pretty sure this is a electronics fault, and due to them having the same components as indesit can be quite a nightmare to pinpoint as well as expensive. these machines usually come with a 5 years parts warranty so you may be better off paying for a hotpoint engineer to call out.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 01, 2008
Getting F-02 error code
wt-960 1600spin washing machine show error code f-12 each time
you switch on
Jul 21, 2014 | Hotpoint Ultima WF860 Front Load Washer
My machine is showing error message F12
f12 is a error of the module not talking to rest of pcb's,, most probally needs replacing,, either do yourself quite cheaply, or get ripped off from hotpoint,,
Sep 12, 2013 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf840 is displaying f-12 and wont start. Whats wrong with it?
  • F12 - Communication error
  • A thing to do is reset machine to do this unplug for 5 mins and plug it back in if still does it then check the wires into the pcb board to see if wires have come loose or water is on it hope this helps
Jan 06, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 1600 spin machine keeps flashing F12. How can I solve it please???
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Hotpoint Ultima WF860 Front Load Washer
What does f-12 mean on the control panel and how do i get rid of it
The Hotpoint F12 error is a Serial Communication Error.
This is a communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  1. Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  2. Check the Drive system for any worn or failed components
  3. Check MCU
  4. Check CCU
  5. Check Motor
  6. Check Wire Harness
You may be able to reset it by switchg off the AC power to the machine and leaving it for 30 mins. Then switch back on to see if the error persists.
    Nov 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
    My hotpoint wf860 washing machine is stuck on f-12 iv tried switching it off and on but still saying f-12 can you help?
    f12 is an electrical connection problem between the 2 circuit boards of the machine. it may be a loose connection or more likely a new power board required.
    Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint ultima wf860
    Hotpopint Washing Machine WT741 flashing F-12
    Resolved the problem.
    Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
    On reappling the power to the machine the orignial programme continued to completionj
    Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
    My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you
    Hi.
    F12 indicates 2 or 3 differant faults.
    Try these first.
    Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
    Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
    Select a drain prog, and see if it pumps out o/k.
    If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
    If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
    Plz rate my solution .Thanks.
    Dec 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
    WF860. Machine auto fills when power come on
    this is for standard hotpoint washers.
    F12 - No mixed fill. It is likely that the water is not turned on at the taps.
    this is for hotpoint lcd evo1 washers.
    F12 - Communication error - Book a service engineer.
    this is for hotpoint lcd evo2 and v4 washers
    F12 - No communication between cards - Book a service engineer.
    please do not for get to rate and comment about your experience with fixya today.
    Aug 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Hotpoint Ultima WF860 Front Load Washer Logo
    128 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
