Question about Sony Playstation 3 (PS3) Console
No video output
The ps3 is plugged to a TV but I have no video the screen is blank.
I use 3 wires 2 for audio 1 for video.
The unit is turning on or off without a problem.
I found the fan was not working but I made it to work with an external power supply of 7 volts.
Give me a note what can be the problem I hope that the video controller is good.
My email is peter11742@hotmail.com
Well it might be the tv you are using because this happend to me but when i bought a plasma tv with built in hd it started to work perfectly.
Posted on Jul 29, 2008
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like sound problem, video output problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Plugged ps3 into tv but nothing is happening. av1 and 2 are not getting anything up on the screen?
1 I take it that you are using the right connecting cables which are compatible with PS3 system. 2 Check the cables are securely inserted. Try disconnecting the cable from PS3 system and TV and reconnecting them. 3 If the video output settings on the system do not match with those of the cable or TV there is no picture. In this case turn off the system. With only the system and TV connected touch the system's power button for more than 5 secs to turn the system on. The video output settings will automatically be reset to the standard resolutions. 4 If the resolution of the video is not supported by the TV the screen will be blank. Then go to system's output settings on the screen, select "Custom" and then select all the resolutions supported by the TV
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*Check that the input mode of the TV is appropriate for the connector in use on the system.
*There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
*If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 nothing appears on my television!!!
ok, put your ps3 in standby mode(solid red light) then hold the power button. Just keep holding it until the picture shows up, asking you if you want to set in to optimal video settings, in which you say yes. if it turns of before saying this, try again and again. if after a few tries it doesn't work, check the cables in the back of the system and tv to make sure they're plugged in fully. then check to make sure your tv is on the right video setting (video 1, 2, 3, digital output, etc.)
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 no picture on screen. Borrowed Unit from a friend.
If the TV was originally set up on an HDTV via HDMI cables you'll have to reset the video/audio outputs on the PS3. When you turn the PS3 on hold your finger down on the button until it beeps a second time, then remove your finger and let the console restart. That should reset the PS3's video output.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
How do i reset all my settings for my PS3? I've been using an HD cable for my video/audio output and when i switch to the regular cables the screen just stays blank and I can't get to the menu. How do i...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Aug 01, 2008 | Video Game Consoles & Games
Mode not supported with playstation 3 DVI input
@ddkim From standby, press and hold the power button until you hear a second beep. this reset the display settings, and may work - Cheers JB
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
