Question about Philips GOGEAR SA6045 MP3 Player
Power wont stay on
Ok i tried to delete a recording on it battery was full and everrything and it turned off now every time i try to turn it on it gets to updating player and turns off again i plugged it into my computer and it still doesnt work what should i do????
  • soccersavvy1 Jul 31, 2008
    i havnt had my philips go gear SA6045 for ver long and last night it just wouldnt let me turn it on. the battery was full then i tryed tp plug it in to the computer and it said i had to install something for it to work and at the end of the instaletion it said do not instal. so now i cant plug it in to the computer or turn it on
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
The run the Repair and the Update in Philips Device Manager.
Posted on Aug 14, 2008
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
Okaay , so my mp3 just stop working it dosent turn all at all I was recording a song on the radio which you can do with my rca m4304-A mp3 can do and i have to press the power button so it can stop...
When the M4304 keeps shutting off all the time, you did well by trying to charge the player: 3 hours of charging the battery, with the player connected to a running computer, should be long enough to charge to full capacity.
1. Check the HOLD switch ( ) on the rear: move the switch away from the padlock sign.
2. RESET the player: hold the Menu button ( ) for more than 10 seconds.
672907e.jpg 3. If the player doesn't work normally after the RESET: perform a firmware UPDATE. For details, see next link:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7312/session/L3NpZC93SFVIdXA1aw%3D%3D/p/158/r_id/162/sno/0
Jul 20, 2010 | RCA M4304 Digital Media Player
Unit wont turn on
Try a new battery... sometimes battery do that kinda' stuff with full battery power. Happened to my Moto Razr o,o
Apr 10, 2010 | RCA M4204 MP3 Player
Wont turn on screen remains black as in not on black and it stays this way even when plugged in
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
Wont start!!
This will take care of it.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e260 MP3 Player
My sansa wont work HELP PLZ
Ok, I have a Sansa e250 2.0 BG. I have an extra memory card but w/e thats not part of the problem. So, when I downloaded music, I accidently put more music on the Sansa memory and it made it too full. So now it has to do a system restart everytime I turn it on. Which is really annoying. And then I tried to delete some music so It would stop doing that and I could update it, But it shows up on my computer as there being no music. So theres nothing to delete! But it says the memory is full! HELP!!!!
Mar 22, 2007 | SanDisk Sansa e250 MP3 Player
Frozen, and invisible!
Maybe your USB connection is not right.
I've had similar problem on C-100, an older model.
Main Menu
Setting USB should be MSC (if you use WMP9 or older)
USE autodetect if you have WMP10 or 11, (MTP)
Hope this helps.
DOn't plug in your sansa to your computer when changing these settings.
Feb 14, 2007 | SanDisk Sansa m240 MP3 Player
My mp3 wont turn on
I had the same problem. I just bought one for myself and used it for an hour while turning it off and on successfully about 5 times, and then it just stayed on. It was on for 5 hours stuck in the same position , frozen in time, until I could get home. I unscrewed the back, took the battery out, put it back in and now it seems to work normal. Hope you tried to do that. I think it will fix it. Hopefully it's not an ongoign problem. I've only had mine for one day so far.
Dec 26, 2006 | SanDisk Sansa e250 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
49 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
