Question about DeLonghi Heating & Cooling
Air conditioner is leaking on the floor - DeLonghi Heating & Cooling
    Scholar:
  • 121 Answers
Hi! siswebster7
Is this a window or wall unit. If so the unit is not tilted so the condensation can run away from the room, or the condensation drain is pluged.
InMrFixIt
Posted on Jul 28, 2008
Water leaking on to passenger floor from air conditioner
sounds like a heater core. when one goes bad it leaks onto passanger floor.
Apr 12, 2013 | Bosch 2005 Saturn L300 Cabin Air Filter
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
Air conditioner leaks on floor
Sounds like the outside drain is stopped up.
There should be a tube coming out of the firewall near the passenger floor.
Jul 29, 2012 | 2001 Cadillac DeVille
Water leaking
depends on where its leaking. Air conditioners create condinsation it is a by product of it function. the water should drain thru a drain line and either go into a floor drain a pump or outside. if its leaking all over your floor it may be a clogged drain. If its not working well too then it may be freezing up and causing excessive condinsation beyond the drain area. you should make sure your filter(s) are clean and the drain is clear.
Sep 18, 2009 | Heating & Cooling
My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Jul 26, 2009 | Pelonis KCD-25YI Air Conditioner
Water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Jul 23, 2009 | Heating & Cooling
Unit leaking
leakage from my central air unit from drain pan, please help
Apr 29, 2009 | Whirlwind FH-778 Air Conditioner
Is there a connection between a warm floor and a water heater?
Is the floor warm just in certain spots or all over. If just in a certain spot you may have a hot water line leaking in floor.
Feb 06, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
169 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
