Question about Philips GoGear HDD1830 MP3 Player
Power Ok i tried to delete a recording right and it just cut off now every time i try to turn it on it gets to where it says updating player and turns off again i tried hooking it up to the computer and it does the same thing what should i do???
  • 8,596 Answers
Recovery Mode for Philips' GoGear
Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Posted on Sep 04, 2008
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
Olympus vn 240 is not recognized by Vista - even after installing update
12. Click Next
May 04, 2009 | Olympus VN-240 Digital Voice Recorder
Digital wave player wont pick up recorder when i plug it in
12. Click Next
Apr 02, 2009 | Olympus VN-4100PC Digital Voice Recorder
Vn-120 cant get it to work
12. Click Next
Mar 01, 2009 | Olympus VN-4100PC Digital Voice Recorder
Do you have the downloads for vista yet?
12. Click Next
Jan 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Power wont stay on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
The run the Repair and the Update in Philips Device Manager.
Jul 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Samsung yp-u3j ZB/XEU freezing/computer not recongising after i deleted files from the device
Hi...I find the answer...Push and hold rec button and button for holding...And it will start..
Jan 26, 2008 | Samsung YP-U3JQB MP3 Player
HDD locked?
Have you tried resetting the recorder to it's default settings either through the menu or by pressing and holding the power button while unplugging it. After unplugging leave it of for a few minutes and then turn it on again.
Jan 15, 2008 | LG RH266 Recorder
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
Can't delete my music!
If you are able to use the Sansa Updater with your player, try formating it and using the updater to fix the things that are wrong with it. To format your player: 1) Goto "My Computer" and and right click your player's icon. 2) Move down the little menu that pops up when you right click it to "Format..." 3) Then, "Quick Format" it. 4) Then unplug your player from your PC. To download the Sansa Updater: 1) Click this link: http://sandisk.com/Retail/Default.aspx?CatID=1376 2) Follow the instructions to install it. To get it to work: with most PC's it should load up all by it self when you plug it in if it is in a MSC mode or if it does it in a regular mode. (I have had no experience with this model only the newer Sansa models) NOTE: If you have Windows Vista, the updater will NOT work. You will need to contact th company through their website to get a different version of the updater. Good Luck! I hope this will help you in fixing your player. Have a nice day.
Jul 16, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
