By "throttle body carb" I am assuming you to mean that the engine is equipped with Throttle Body Injection (TBI). The O2 sensors on that engine do not even start working for about 5 minutes. They are not going to cause a problem on start-up. A fuel filter will most likely not cause a problem on start-up or idle either. A fuel filter is most likely to cause problems on acceleration or when pulling a hill. A more likely cause would be a n Engine Coolant Temperature (ECT) sensor. If one of these is reading too low, it will cause the engine to flood and smoke black out the exhaust - especially on start-up. (LIke a choke sticking on an old carbureted engine.) If your truck is equipped with a gauge, there may be 2 Coolant sensors. One for the gauge and one for the computer. If you replace it, make sure you are replacing the sensor for the computer.
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads,
brake pedal remains on floor?
http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC)
Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows
hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles
like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This
will help.
Thanks.
