Question about LG DLE3777 Electric Dryer
Dryer wont heat!
It turns ON, it rotates just fine, but wont HEAT!!! i need help plz!!
  • thekirkhams Aug 06, 2008
    Dryer runs but no heat I have looked at cord thats fine the dryer is about 3 years old. looked at breaker nothing turned off help.
It could be a problem with the terminal block in the back of the dryer.  You'll need to unplug the dryer and check the block.  I learned this on home depot.com/ApplianceRepair.  Should cost you under 75 dollars to fix if you do it yourself.
Posted on Aug 01, 2008
Dcvh660ghbb dryer wont heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Sep 05, 2013 | GE Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer wont heat up.suddenly stopped heating...rotates just fine.. Kenmore 400 seriies gas dryer..please help
Make sure to check all the thermal fuses in the dryer.
if one of the has not got any continuity then replace it.
there is also a chance that the ignitor has gone bad and is not allowing the gas valve to open.
Jul 03, 2010 | Dryers
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Bearing replaced on Dryer
The first place is to check you incoming power a dryer will rotate but wont heat if ony one leg of the 220v pwr is coming in do you have a meter to test ?? you can also go to the breaker panel turn off and back on the breaker as a weak breaker will do this if you have done this and still no heat you will need a meter to check some things also if you remove the 3 screws on the panel between the washer and dryer you will see the element.Make sure to turn the pwr off before touching any wire connections..Let me know what you come up with
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer
check for a lint blockage in the blower discharge line. there is a quarter size overload in the metal blower line. evidently the heat is building up to the point that the overload is kicking out. once it's cool it operates fine.
Aug 30, 2007 | Dryers
LG DLE3777 Electric Dryer Logo
388 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
