Question about Canon Office Equipment & Supplies
My Canon S600 Bubble Jet Printer ran out of paper. I put in the paper and pressed the orange blinking button to resume printing. However, it won't continue, even though I've cancelled the print job. The orange button keeps flashing even though I have rebooted and done everything I know how. What's the solution?
  • 11 more comments
  • Liebsch Jul 28, 2008
    A printing job was in the works; the paper ran out, so the orange light started blinking. I put in more paper, held the orange button down like always to resume printing, but nothing happened. I've shut the printer off, restarted it, but the orange lights comes on again and continues to blink. I've cancelled the print job in my "control panel", and no printing jobs show up now. However, the orange light continues to blink! What's up?
    I went to control panel, clicked on Printers & Faxes, right clicked but found only "Use Printer Offline"......not "online" as you suggested. Now what?
    Well, I downloaded the new drivers for the Canon S600. Still the same problem exists...the orange light is blinking and it won't print.
    How do I do a test print with the utility print?
    The computer and printer cable are intact...otherwise the printer lights wouldn't be working. Is that correct?
    I unplugged the printer from the computer, turned the button off and on several times. Nothing helped. Then, I removed and snapped back in the ink cartridges. Still the printer light is blinking orange. Any other ideas?
    Where do I find the "utility printer"?
    I'm getting frustrated with this problem...all your suggestions have not worked!
    The orange light is flashing continuously...nothing is working!
    Yep, I've re-plugged both ends of the cable -- into the computer and into the printer. Still, the orange lights keeps blinking.
  • Liebsch Jul 29, 2008
    Since you haven't helped me solve the blinking problem, I'm taking the printer to a repair shop for analysis. I'm disappointed with the recommended solutions that didn't work!
    I don't use "refills" for my ink cartridges; I've had little or no luck with them. I buy new ones...Canon brand...so I doubt that my ink cartridges would be dry, since I use them on a regular basis. Any other ideas?
  • Liebsch Jul 30, 2008
    I've tried that too. Still no luck. I took it back to Best Buy, but it would cost for S&H to Chicago, plus any labor/repair. Now, I hope you don't charge me too for the $9.90 on my credit card. I didn't get any solutions from you!!
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
It means a paper jam... make sure there is no paper anywhere in the printer, then disconnect power for 30 seconds. Turn it back on and watch to see if it tries to feed paper. If not you have a broken paper sensor. Also check the cartridge any mismatch?
Notes - BJ Cartridge Mismatch
This error can be caused by installing the BJ Cartridges (Printheads) in the wrong position in the printer. The Correct combination are as follows
Left Holder Right Holder BC-30 BC-31 BC-32 BC-31 Insure the Cartridge lock levers are down. Reinstall both Cartridges.
Also doing the Waste Error Reset.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
If it is not fixed u NEEDS SERVICE. CONTACT CANON AUTHORIZED SERVICE FOR HELP
THANKS
GOOD LUCK
Posted on Jul 30, 2008
    Novelist:
  • 183 Answers
Hello Liebsch
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
  • Press the On (My Canon S600 Bubble Jet - fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
  • 10,594 Answers
Get new branded Ink Cartridge and replace it. Simple!
Posted on Jul 29, 2008
  • 2,071 Answers
If it not a piece of tape and there are still flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
  • 868 Answers
Replace the printer cord.
    Genius:
  • 1,011 Answers
Dear,
check the paper tray by removing and fixing it again. do a cleaning method of your printer. hope it will start working.
regards,
  • 818 Answers
Canon that the lights are flashing because you refilled. If so the problem maybe that the ink is not making contact with the sensor. Remember when refilling the ink must have a steady supply of ink flowing into the nozzles. Sometime because of delay in refilling you will get pockets of the sponge where it has dried out and the ink is restricted in its flow to the bottom of the cartridge. Therefore the printer will show the cartridge full but because the ink is not contacting the sensor as it prints the lights will blink. These types of cartridges will dry out also if they sit to long.
I suggest buying new cartridges and try refilling often this will solve the problem. Or another way to fix the ones you have is to remove the ink and add 1/2 mil of Isopropyl alcohol to the sponges allow it to sit for a few minutes so the alcohol runs down to the bottom of the cartridge. Moisten the bottom with alcohol as well. Put scotch tape (securely) over the port hole on the bottom of the cartridge. Let the cartridge after you injected the ink to sit over night in a saucer this allows the ink to migrate through out the sponge. Install and if the error appears a gain try the 70 second unplug and re install once again. If this occurs once again the problem may not be the cartridges but your print heads. The ink for refilling and having success should be dye based inks, pigmented inks may be a closer match to the original ink but will clog the print heads and burn them out.
Posted on Jul 28, 2008
  • Canon Master
  • 13,433 Answers
    Genius:
  • 1,689 Answers
The printer utility is the application you installed from the CD, the one that monitors your ink level and alerts you of paper refill.
  • 928 Answers
Disconnect the printer from the computer. Turn it off and on. If the orange light is still blinking. remove the ink cartriges and put them back in and turn off and on the printer again. The orage light should not come on whether or not it is plugged into the computer. Drivers also have nothing to do with the problem if the printer is not plugged in the computer. This will help you isolate the problem further.
  • Thomas Lim
    Thomas Lim Jul 28, 2008
    1. Try this printer reset for your model.
    2. Turn off the printer ( “Power” button).
    3. Hold the button “Resume”, include printer (click “Power”).
    4. Hold the “Power” button, release the button “Resume” (power indicator / preparedness must turns green)
    5. Not releasing the “Power” button, double click “Resume” and release both buttons
      • each time you click “Resume” power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
      • after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
      • If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
    6. Four times click “Resume” (each time you click “Resume” power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
    7. Once you click “Power” to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again. For some printers to switch off clicking “Power” again, that is three in a row
  • Canon Master
  • 6,487 Answers
Can you still do a test print using the printer utility ? Just to check if the printer is still be able to print..
Hope that helps.........
  • 1 more comment
  • Mark Gil
    Mark Gil Jul 28, 2008
    Better try uninstalling the printer and resinatll it back...
    Good luck.
  • Mark Gil
    Open the printer utility and there's a option there that says test print.. If it doesn't do a test print better uninstall/reinstall the printer....
  • Mark Gil
    You should have installed it when you run the software of it.
    Try checking it under all programs look for anything that says Canon...
  • 4,472 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=7096
Select your operating system and download the driver. Install that and see if that helps. Make sure your printer is unplugged before installing the program it will prompt you when to plug it in.
Thanks,
Lee
    Genius:
  • 1,269 Answers
Try to restart your computer. After that, go to Control Panel > Printers and Faxes. Right-click your default printer and click "Use Printer Online".
    Sergeant:
    Champion:
  • 347 Answers
Hello liebch,
Make sure the paper is placed correctly and the printer have ink.
Then press the orange blinking button, and if it dosent work then, unplugg it and plug it back. Turn it on and see if it works.
Good luck and anything else you need let me know,
Dahaka
  • 2 more comments
  • Santiago Vallejo
    Santiago Vallejo Jul 28, 2008
    Check that your conenction between the computer and the printer is okay. It might be unplugged.
  • Santiago Vallejo
    Liebsch,
    If the light turn on it means it have power.
    So the cable can be unplugged from the computer and it will still power up.
    If you say your printer is not detected on printers and faxes on the control panel, then there is a problem between your computer and your printer.
    Most likely the cable.
    If it is firmly plugged, re-plugg it back on both ends and if the problem continues, let me know,
    Dahaka
  • Santiago Vallejo
    Did you already check the connection to your computer from the back of your printer?
  • Santiago Vallejo
    Okay  Liebsch,
    Could you please tell me how many times does the orange light flashes?
    It will flash for a number of times adn then start over and over again that same number of times.
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
How to I access canon s600 ink pad
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on s600)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 13, 2009 | Cannon Canon i960 Photo Printer
I have a canon iP90 printer and a code is coming up 5C00?
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
If it still comes up with this error there might be some paper down near the print heads. If there is no paper there, you might have an actual hardware issue.
Aug 29, 2009 | Office Equipment & Supplies
The printer is showing "waste ink collector full",not printing
Most cannons reset the same try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes
May 07, 2009 | Canon Bubble Jet S900 InkJet Photo Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
Am receiving 7 orange blinks on printer Canon S900--book says bad printhead--is there a possible fix or does it need replacing?
1) Power off printer
2) Hold RESUME button then press and hold POWER.
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times.
6) Press power to set data.
Mar 21, 2009 | Canon Bubble Jet S900 InkJet Photo Printer
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
Jun 04, 2008 | Canon I990 InkJet Photo Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
222 people viewed this question
old marine
old marine
