Question about Lands Phones
When i call using my A88 phone, the call receiver hears their own voice echo. How can i fix this problem
Only solution I found was turn speaker on, then off... this is annoying, but works...
Posted on Aug 21, 2008
I can receive calls in, but when I call out, I just hear my own voice echoing.
If you're using a voip network you need to turn it off and wifi. If it correct it then that's the issue and I'd do a factory restore
Jun 23, 2016 | Panasonic KX-TG4134N 4 Handsets Cordless...
Dial tone sounds static and voice echos. How to fix?
Hi anonymous, ;)
You can try to reset the phone by disconecting the battery..
Rconnect and place it on the receiving unit to reconnect it to the network
Apr 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
Bad echo in ear piece while talking
You can try adjusting the volume and see if any results. Try to verify if it is a hardware defect by using a Bluetooth piece and if you get better results.
Nov 08, 2013 | Plantronics CS530 Wireless Headset System...
I hear echo
Are you or the other person using the speaker phone function? Does this happen during conference (3 way) calling? If you're using the speaker phone function, especially during a conference call, you're likely to hear an echo. I've had this very same issue with a different phone and the only solution I found was not to use speaker phone.
Good Luck!
Jan 05, 2013 | HTC EVO 4G Smartphone
Echo occurs on voice chat
just down the mic volume and see als run the sound diagone test.
Sep 08, 2009 | Logitech QuickCam Communicate STX Personal...
T7316 Dropped calls and voice echo
How are your lines coming in to your phone system?
Generally you get an echo on VoIP lines not set up correctly.
T7316 should not give echo, as it is a digital phone.
May 29, 2009 | Lands Phones
Echo on line and dropped calls with A88
I dont know on this exact phone but here is for a similar see if this will work for you.
First make sure the User profile you activated has the Ring type set to Repeat so the ringtone works continually
rather than ringing once & stopping! Go to Main menu => Settings => User profiles => [Select a profile] => Customize => Ring type = Repeat
Save the settings & as you back out of the menus make sure the profile is Activated, as it should have a large green checkmark next to it.
If this setting is already set to the Repeat option, and your ringtone does repeat, but just doesn't seem to ring enough times, read below.
Also see if your phone has the below settings somewhere in your phone's menu system. As firmware are different so can the menu system
be different. If you cannot follow the exact path to find the option below, look in other areas of your phone's settings for the settings, but
know that your phone just may not have the same settings anywhere.
Call History => General Settings => Sim1 Call Settings => Call Divert => Divert if no Answer => Activate => To Voice Mail =>
Now choose the time length you require, 5, 10 15, 20, 25 or 30 seconds.
Mar 22, 2009 | Dual Electronics CECT P168 Cellular Phone
I have a Samsung SGH-a517. The phone was working fine until yesterday. When receiving or making calls the opposite party can't hear me, although I can hear them. Also, I can hear my own voice echo about 3...
You will need to send you phone in for repair since the mic is part of the mainboard and will need to be fixed by tech or they will probably just send you another phone.
Jan 24, 2009 | Samsung SGH-A517 Cellular Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
