Konica 7022 Fax kit FK102
I would like to know if this FK102 has faxability and how to turn it on, and if not how do i increase the number of rings on the fax unit?
cheers
  • Hadley Hudson May 11, 2010
    Is the unit already installed in the back of copier.The unit is plug and play meaning once installed it ready to go.The # of rings is located in operator's manual.
SOURCE: NUMBER OF RINGS TO ANSWER FAX
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
change the number of rings.
4. Press OK to accept the setting.
Posted on May 14, 2008
SOURCE: Distinctive Ring Fax Receiving
I have a brother MFC - 425CN fax machine and need to change the distinctive ring to a duet line as I have no provision for this is the manual i got with the machine.
Can you please assist
Posted on Sep 18, 2008
tech435
  • 284 Answers
SOURCE: Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: Konica 7022 Scan to Email Upgrade
I have never heard of a "kit" for scan to email. What I think they may be telling you is that you need to upgrade your Memory in the machine. The Memory that is standard in the machine may be limiting you to 10 pages, or the email service you are using is limiting the size of the file you are recieving. Are you using an inhouse mail server or an outside source like AOL, Gmail, Hotmail? Again, I have never heard of any "kit" for scanning at all. Hope this clears up some of the confusion
Posted on Feb 17, 2009
firecontrol7
  • 6359 Answers
SOURCE: Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Posted on Aug 01, 2009
Konica 7020 how to enter the service mode
Which one the they have three mode 25, 36 and 47 depends on what you want to do.
Oct 11, 2014 | Konica Minolta Fax Kit Fk-102 For 7022...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Feb 10, 2009 | Konica Minolta Office Equipment & Supplies
Increase the number of rings
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Need to know how to change the number of rings on the fax.
Press
Funcion
7
monitor key slowly 4 times
set
clear 2 times
use number pad to set number or rings 0-15
set
Unplug power cord, plug back in.
Nov 26, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Feb 12, 2008 | Konica Minolta Minolta DI1610FP...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
275 people viewed this question
jasbo
jasbo
