Question about Alpine CDM-7861 CD Player
How do I set the time?
I can generally set the time on other radios but this one has me stumped.
Setting Time
While the clock time is displayed, press and hold
the CLK (clock) button for at least 3 seconds.
The time indication will begin to blink.
2 Press the CT button while the time indication is
blinking to set seconds to "0".
3 Press the "H" button to adjust the hours while the
time indication is blinking.
4 Press the "M" button to adjust the minutes while
the time indication is blinking.
The time indication will stop blinking 5 seconds
after the last adjustment. The time will
automatically be set.
Posted on Dec 28, 2008
How do I set the alarm on my Nelsonic NLC690 alarm clock radio to 94.9 the bull?
Set the radio so you can hear 94.9. Set the Alarm Time, set wake by radio as opposed to alarm.
nelsonic clock radio nlc 690 manual Google Search
General info on that type here
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
And a basic more modern one like yours. You can get yours from Walmart, so you could go in and ask for a photocopy of the instructions.
http://jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf
Aug 15, 2017 | The Audio Players & Recorders
I have a General Lee I am Working on. It has ears But will not Dead Key. Replaced Both Finals, Driver, Audio IC . I am Stumped :-(
On the RF Hi Lo switch do you have power? Is the switch ok? That switch regulates the TX power and if it is open, you have none.
Apr 12, 2016 | Connex Radio Communications
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
How do I set the alarm?
On what exactly? If you're talking about a general standard clock radio, there will be an alarm button, which you hold down whilst pressing the hour and minute button to set the time. For "setting" the alarm, generally there's a switch on the side.
Aug 09, 2015 | Audio Players & Recorders
How I set the time on the radio?
Depends on the radio.
General idea is this:
turn radio power off on face of radio. Clock should show.
push button such as SET / CLOCK / TIME
push other button HOUR MIN up down seek scan ff rew (one button will control hour other button will control minute)
turn radio power back on. clock should remain set.
Dec 06, 2014 | 1993 Buick LeSabre
I bought an 2 ch. amp and a sub for this car. I'm nearly finished the hook up but only one is stumping me. Where is the remote turn-on wire or what color is it?
remote is generally blue out of the deck however if it is stock radio wire the amp remote to the accessory circuit on the back of sterio this will turn on the amp when your radio comes on instead of the radio turning on the amp there should be a memory wire that is hot all the time and a accessory wire that turns on the radio when the key is on
Oct 16, 2012 | 1998 Ford Taurus
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
Oct 27, 2010 | JVC Car Audio & Video
Wiring
If you have 2 wires that are the same color and one of them has a black stripe down it, those are speaker wires. I.E. if you have 2 greens , one with a black stripe, that goes to one speaker. You'll have to play with them to know which is which. I have moved the radio settings to front right speaker, then kept changing the wires from the car out until the car's front right is on, take note of the speakers that come on in the car while you are trying to find the right one so when you are ready to hook it up you know where to go. Yellow goes to constant power, even when the car is off, and key out, thats why you don't have to reset the clock every time you start it up. Red generally goes to power when the key is in the on position. Blue is for remote operation, like turning an amp on or off, so it doesn't run while the radio isn't on. I don't recall any others off hand that are critical, but do consider this, if you have a newer vehicle with factory radio, it might need a conversion module in order for it to work. Generally you can tell if the radio has a volume adjustment for speed, e.g- it gets louder as you go faster and softer when you come to a stop, you will need one. You could hard wire it in without the module but the radio plays a role in the horn and chime operation, if you dont get the module you will pay for it,.....trust me. Also, if you get it all wired in and nothing is going on, plug in the antenna, that serves as the series ground, hope this helped.
Apr 06, 2008 | Pioneer DEH-3700MP CD Player
Frontera sport niagara
Don't know why this was classified under Radio Scanners, it sounds like it's an automobile question.
2-high will be best on gas by far as the engine no longer has to drive a transfer case to get torque to the other 2 wheels.
4-high will be next in line and should only be used on slippery surfaces (ie: snow, dirt roads)
4-low will probably only get you up to 30 mph since it has an entirely different gear ratio. Most people hardly ever use 4-low except when pulling stumps in the back yard.
For general use, stick with 2-high. Best fuel economy and performance.
Mar 10, 2008 | Radio Communications
Alpine CDM-7861 CD Player Logo
1,388 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
