Question about Tappan 30IN ELEC IGNa Oven
The pilot light for the oven went out.
Model No. TPF303BWB Serial No. VF34241921
How do I relight the pilot light for the oven?
  • 1 more comment
  • pw4ubo Jul 29, 2008
    Replace the light bulb. This answer is from an expert? Let me try to explain this a little better. The gas flame that ignights the element in the oven that increases the tempature in the oven so you can bake food went out. Where is the location of the "Pilot" or element that I need to relight in the oven? The oven does not need a new light bulb!!
  • gua718 Oct 04, 2008
    A similar thing happens to me, but after a few minutes, the oven DOES turn on. So there's a gas smell for a few minutes. The ignitor seems to be working when I turn the oven on, but the burner doesn't turn on until after a while. Any suggestions?
  • Anonymous Mar 19, 2014
    3270-2 pilot lighting problem all clean seems to to much air for pilot to light
    Genius:
  • 1,665 Answers
Relighting Your Furnace's Pilot Light
The pilot light for the oven went out. - furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Posted on Jul 29, 2008
  • Tappan Master
  • 19,396 Answers
Replace the bulb, you can buy replacements here
Posted on Jul 28, 2008
  • 2 more comments
  • Ginko
    Ginko Jul 29, 2008
    You might need to pull up the bottom plate of the oven. Newer ovens, like yours, do not have a standing pilot light, they have electic pilot
    starters that light the pilot when the oven oven is turned on.
    Sorry about first answer, I did not read correctly, sometimes happen to us.
  • Ginko
    Ginko Jul 29, 2008
    If the oven does not ignite, you just do not relight the burner with a match on a modern oven. Check if you smell gas. Probably it is just a broken ignitor.
    To test the ignitor, the only way is using an Amp Probe .
    replacing the ingnitor solve the problem in majority of similar case.
  • Ginko
    Ginko Jul 29, 2008
    This should be the replacement needed for your range.
    Double check part is right for your model by contacting seller at 800-269-2609 (USA toll free number) or email at Contact Repairclinic before buying the part.
  • Ginko
    Ginko Jul 29, 2008
    Sorry, missed link, to contact part seller use contacts listed in this page (click), thanks.
2 Suggested Answers
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
How to relight the pilot light on the whirlpool super capacity 465 oven
Rebecca Yount, we're sorry to learn that your Oven will not ignite. We recommend service due to we aren't certified Technicians and wouldn't be able to advise you on how to relight the pilot light on your Oven.
Oct 17, 2017 | Whirlpool Ovens
Kenmore Oven- The oven doesnt heat or light at all. If I sent it to 350 degrees; should i still smell gas?
I beleive this model has an electric igniter, You may have to change this they sometimes just wear out, or it's just simply your pilot light is out and you need to relight it, hope this helps.
Sep 19, 2012 | Kenmore Ovens
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
How to I relight the pilot of the burners on my kenmore 362.72201891 oven. Not the oven pilot but the burner pilot light.
Hello, Thank You for using FixYa. I will be helping you today.There are no standing pilots to light.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Kenmore Ovens
My gas stove, the top works but the oven doesn't. I think the pilot light went out,how do I relight it?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Feb 12, 2011 | Maytag Ovens
Pilot light is out but can't figure out where it's located in order to relight it. model is Frigidaire ES340
FROM WHAT I RESEARCHED ON LINE THE ES340 HAS HAD A LOT OF PROBLEMS AND THE MODEL NUMBER IS FOR AN ELECTRIC RANGE MAYBE THAT'S THE PROBLEM
Aug 11, 2009 | Frigidaire Ovens
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Nov 16, 2007 | Ovens
Tappan 30IN ELEC IGNa Oven Logo
1,066 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
