Question about RCA Universal Remote Control
Remote we pushed a button on remote and a black square shows up on the screen while trying to watch
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): remote - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
• Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
Jan 08, 2013 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
A black square pops up on the screen while watching a show. The only way for this black square to go away, is to turn up or down the volume.
Check your closed-caption settings and be sure it's turned off. Captions have gotten turned on and set to "text" mode, and the set is blanking out the area where the test would go. This often happens if someone presses the button on the remote that controls caption settings without realizing it.
Sep 18, 2011 | JVC AV-27F475 27" TV
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
I get a black square in the middle of the tv. I can still see part of the program and hear it but there is a code or something that pops up it starts with lid and has numbers following. If I push the input...
U have the tv original remote wright?Yes.Used ur tv remote look for a button that said CC.Pushes a few times make sure all like CC1,2,3 so on to all off.The black square box show up in the middle of the tv screen,numbers and printting words on the screen it is are call Close Caption for the hearing impair person to read,will disappear from the middle of the tv screen.
Apr 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Our Sansui 32 inch 3212 has a blacked out triagular area in the middle of the tv screen that comes and goes. What could be the issue.
U still have Closed Captioning functions are on.Check ur remote control for a button that said CC.Used that button pushes couples times for all CC1,2,3 to off.Should have no more black squares showing up the tv screen again.
Dec 24, 2010 | Sansui HDLCD-3212 32 in. LCD TV
How to reset closed captioning on a sanyo flat screen. Followed all directions 3 times and no writing on the screen. Grandpa needs it to watch his tv.
U have CC button on ur remote?Push that button on like CC1,2,3 one of these will get u captioning,but the show must have captionning in it programming it have CC and a square before show started it indicated it have captioning.
Mar 18, 2010 | Sanyo DP32746 32 in. LCD Television
Black square
hi! goto menu then, turn off the caption >avtrac
May 25, 2009 | Televison & Video
Screen problem
That's the text box function of the closed caption decoder. Look for buttons with "CAP", "TEXT","CCD", or "CLOSED CAPTION". Look in menu for same.
Nov 11, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Televison & Video Logo
128 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
