Question about Gigabyte GA-8KNXP Motherboard
Installing 4 SATA hard drives on the GA-8KNXP mobo
I am reinstalling windows XP on to my computer. I have 4 SATA hard drives working the C drive is pluged into the SATA0_SII slot and in the BIOS I had under the Peripherals I Enabled "Onboard H/W SATA" plus had the "Serial ATA function" set to BASE. Like this I could read all four drives.
When I went to install windows from the CD it could only read two drives neither of which was the C drive. I didn't format C yet so I tried some settings.
When I plugged the C drive into the SATA0_SB slot, windows would come up with an error, so I Disabled the "Onboard H/W SATA" now windows will start however it only reads two of the four drives.
I have played around with many of the BIOS settings, and where I plug C in but all I can get is either to read all 4 drives with C as the 3rd or 4th drive so windows does not find it to reinstall XP or move the c drive to the SATA0_SB slot and I only have two hard drives.
So my question is, is there something I am doing wrong can I have C drive as the first disk and read all 4 SATA drives at the same time.
Thanks
Kai
  • Mike_G59 Jul 29, 2008
    Thanks for your reply. But I don't understand what you are saying.
    On My mother board there are four sockets to plug the SATA drives into. I have four drives so all 4 sockets are being used. SATA0_SB and
    SATA1_SB plus SATA0_SII and SATA1_SII. This is where my problem is, if I plug C into SATA0_SB or SATA1_SB then with the BIOS setup I can only read 2 drives, not good. If I plug C into SATA0_SII or SATA1_SII and change the BIOS then I can read all four drives however C drive is now number 3 or 4 and I can't reinstall windows onto the C drive.
    If you were saying something else then some more explanation would be helpful.
  • 781 Answers
Check motherboard manual it seems you may have the sata drives plugged into wrong number socket they should have numbers on them sata 1 etc
Posted on Jul 28, 2008
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
How to change bios setting on GA-F2A55M-DS2 motherboard to install XP
The BIOS should not prevent you from installing Windows XP.
If your hard disk is a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 24, 2013 | Gigabyte Computers & Internet
I have mainboard asus p4s800-x i have hard drive 160 GB(SATA) but time reset show me no divice SATA found i do disable chip sata on mainboard and agine enable chip but no effective
If you are using Windows XP, you will need to download the Sata driver for this motherboard, save to a USB or floppy on another computer and when installing windows xp, at the "f6" prompt, direct it to where you saved the driver (ie: make sure the floppy / usb stick is plugged into the computer you are insytalling to), it will install the sata driver and then it will recognise your hard drive, no need to disable the sata chip on the mobo
Apr 18, 2011 | ASUS P4S800D-X Motherboard
Can i install 1 tb hard drive
Your board has (4) Serial ATA (SATA) connectors so you can install an SATA hard drive of any size you want. Make sure you are running at least Windows XP SP 3 because earlier versions had trouble recognizing large hard drives. Also make sure your power supply has connectors for SATA drives. If not you can find 4 pin MOLEX to 15 pin SATA power converter cables on Tigerdirect.com
Oct 16, 2010 | Gigabyte GA-8I915PL-G Motherboard
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
Gigabyte GA-8KNXP Motherboard Logo
366 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
