Screw has worked loose and handle just hanging on door. Other than removing the numerous screws holding the pre-formed shelf unit to the door, is there any way to re-attach it?
Re-attaching the door handles will require you to dettach the front door cover from the actual front door (as shown on the "parts manual") some of the units circuit may run through the door so be careful in removing the front door cover.
once it is removed, the handle mount will be exposed, place the screws if need and use compatible bushings to make sure the screw will be locked in place.
refer to the link below to get the Parts Manual and the Wiring diagram of your firdge.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FFU14K2CW&User=&Search=Search
good luck, i sure hope you get this one working in no time.
-voodoomox
Gorrilla glue bonds to EVERYTHING!!!!
Note: Take care to keep Gorilla Glue out of the reach of
children and pets. It expands in the stomach if eaten and requires
surgery to remove.
You can find it at Home Depot, Lowes, home improvement stores, maybe even WalMart?Use a little, it expands!
You can also use Liquid Nails. They now have a new Liquid Nails that dries clear.For more details please check out their website:
http://www.liquidnails.com
Please don't forget to accept the solution.
I think you can just use a quick dry super adhesive glue to hold the handle in place.
Screw has worked loose and handle just hanging on door. Other than removing the numerous screws holding the pre-formed shelf unit to the door, is there any way to re-attach it? Gluing the handle will not work, it requires some mechanical connection.
Voodoo confirmed what I assumed in my initial request and I guess that is the only way.
