Question about Epiphone EBO Electric Bass Guitar (Refurbished)
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
  • Epiphone Master
  • 5,603 Answers
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Posted on Feb 27, 2011
SOURCE:
Can I use my vox vt50 amp to play my bass guitar?
You can use it, just keep the volume low. The amp doesn't care what yu play through it, but the speaker isn't designed for loud bottom end.
Dec 17, 2015 | Bass Music
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
Warwick xtreme bass amp no sound
get a new amp or try buying a new guitar i do not no ask the people
at gutair store sorry if i can not help
Mar 24, 2014 | Warwick Music Equipment Warwick XTreme 51...
Google: Randall Padilla, that's me.
What could be an issue is if the cabinet is a 4 ohm cabinet and you plug it into the 8 ohm output. of the RT100 ... IT WILL BE LOUDER that way... for a LITTLE while... till the power tubes get gassy from overheating and the sound will GO AWAY. VERIFY the impedance of the cabinet and plug into the correct jack on the RT100. Every RT100 will do this... it is GROSS abuse of the amp if you plug 4 ohm speakers into the 8 ohm jack. Some of the power tubes may conduct so heavily when they get gassy that they will cause a hum before total failure. The tubes will first get red, then orange plates and that drives metal ions out of the plates, then they get a purple glow and eventually blow the fuse or something in the power supply.
May 07, 2011 | Randall RT Series RT100H 100W Tube Guitar...
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
I have a bx4500h and a ultra bass 115 cabinet. the head is fine, but the crossover? is bad in the cabinet. what can i do? can i just by pass the crossover and just use a 1/4" jack straight to the...
does the cab have a horn like the one in the photo if it does then you must think again.
you must try to get a replacement crossover or get a speaker geek to fix it for you its not so hard you can get the burnt out components fro radio shack / maplin so on. most of the blown components will show damage or smell like they are burnt because thats what they are.
the cross over plays a very important job in the fact that it filters of the top frequencies so you only get subs on the bottom 12's bass / mid on the top 12's and hi frequencies on the horn.
you will loose all the quality if you go direct and could easily blow things up especially the horn.
this speaker cab looks like a Kenny i had and when working then they are fantastic. i blow one of the sub 12's and the cross over survived so unplug the speakers and test them 1 by one with a little power from an amp and a small amp that does not matter if it gets damaged
Apr 11, 2011 | Behringer Ultrabass BB410 1200W Bass...
My Fender 212R 100W 2x12 Guitar Combo Amplifier keeps on cutting out. The guy I took it to says there is something wrong with the cylinders? I also could have heard that wrong. I honestly don't know much...
You had best get a second opinion! When somebody says "there is something wrong" means they don't really know the details enough to give you an estimate even. If the amp cuts out sharply I would suspect that: 1. Bad volume control 2. Cracked circuit board 3. Bad solder joint on circuit board 4. Bad jack. These are in order from least to most likely.
Jan 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
My Bugera 1960 stopped working in the middle of a rehearsal. I was playing at about level 3/4 in the 1st input of the 2nd channel. The amp was connected to a Marshall 4x10 bass cabinet. The connection of...
Wiring harness connector to the power tube section is fried. A common problem with all bugera amps and many other companies also. A cheap fix. You can order the part you need from newark.com or call 1-800-4newark the part number is sku#85c0290 mfr#09-91-0500
Nov 25, 2010 | Behringer Bugera 1960 Classic 150-Watt...
Epiphone EBO Electric Bass Guitar (Refurbished) Logo
130 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
