Philips 60 inch projection
I have a philips 60pp9100d\37 that I replaced the small signal board(ssb) and it powers up for about a minute then it goes off and flashes a code 6 I2C error. Do you have any sugggestions?
Thanks
David
  • 1,183 Answers
The I2C message that you get means the Inter IC communication bus on the system board has gone bad. Replacing the IC would not solve the problem.Philips patented this technology to reduce the number of ICs on the systemboard.There would be a physical I2C chip on the motherboard.
You can read about the technology on the post by philips
http://www.nxp.com/acrobat_download/applicationnotes/AN10216_1.pdf
I would suggest update the firmware on the board, or try replacing the I2c interface controller chip.
Thanks
Proton
Posted on Jul 29, 2008
I need the main board for an 03 60in phillips projection tv since i accidently spilled the coolant on it. since it was a huge pain to get into my room so i would like to fix it and keep it
The boards are the AC main filter (power Board) The LSB (large signal Board) and the SSB ( small signal board) Which board are you requireing? Let me know which one and I can assist you with locating the board you need.
Feb 24, 2011 | Philips Magnavox 9P6034C 60" Rear...
Sound went out on tv was told i need a sound module,also need to get price of one
This model had a lot of odd problems including loss of audio.
With back off as you look from back are three large circuit boards.
One on the far left has another board about 4X5 inches plugged into it at the left rear corner.
Every one of these sets, that is the bad board--controls audio, remote and many other things. Large board it is plugged into is called Small signal Board (SSB), small one is small signal module (SSM).
It is plug in board held with two metal tabs at either end on bottom, It will have printed on it a part number (usually on a white label) with the part number, popular one ends in 2581 but are variations.
Last time I used one it was about 100 exchange(they are all rebuilt boards now)
Ten minute task to replace with back off and 95% chance it is your problem.
Everyone of these sets with no sound or intermittent sound, it was the problem.
SD TECH
Oct 14, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 42PF9431d/37 behaving erratically
I would have the technician check out the key board assembly (button panel for lamen's terms). If not,then it could be a problem on the IR reciever board that is causing the small signal board to behave rather unusually. Tell him to check the ir board,there should be a surface mounted capacitor that will read shorted on a diode scale under the infra red diode. If that solves it,then it should cost you no more than 60$ reasonably. The logic board wouldn't have anything to do with the button changing.
I have also worked on a lot of this whole series of philips plasmas, and the control board is the least likely suspect from my experiences
Oct 16, 2009 | Philips 42PF9431D/37 TV
I have 60" projection tv sometimes the picture goes scrambled if you hit beside power switch it comes back on. Sound is there just no picture.
HI,
Common problem on this set.
SSB ( small signal board) Bad.
This part cost about $135-$245.
encompassparts.com
provide model number tv and they will help you.
Thank you
Sep 26, 2009 | Philips 60PP9352 60" Rear Projection...
I have a 60 inch phillips rear-projection tv and there is no picture . There is a whinning sound and the light flashes at the power button. Can I fix it myself or does it need to go to a shop
it is better you get a repair guy to first open the set and to determine the exact problem.
the thing is you may make it worse if something goes wrong
Aug 26, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 60PP9200D/37 60-Inch Widescreen Rear Projection HDTV has sound but no picture
You will need to purchase the small signal board......they are kind of difficult to remove and replace. They sometimes look like a small aluminum sandwich box or they look like a video card out of a computer. Read the instructions to replace and reprogram this. Look up at the Philips Partstore.com. Type in model # and see small signal board......These canbe pricey $$$$$$$$
Aug 04, 2009 | Televison & Video
60 inch tv philips projection sonnd in and out
Audio amps in a Philips PTV is one of the easiest sets to repair. To my knowledge all the individual parts are still available so I see no need to replace the entire amp. know what problem you have first, then we'll try and determine what you may or may not need? They had a board which is called the SSB ( small signal board ) that used to go bad creating similar symptoms like that. That board is the size of a 3x5 photo and stands up on the left side of the chassis, anyway let me know?
Feb 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Dec 13, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
