Question about HP Photosmart MZ67 Digital Camera
Lens Error Thte lens will not go back in.Says "Lens Error"Code Mz60-033Took it into store where I purchased it. They said to contact hp.
  • 1 more comment
  • Logan01 Dec 21, 2008
    Got the same problem, lens won't go all the way back in error code MZ67-033. Have changed the batteries with new and get same error. I can't believe the lens are dirty or damaged as I haven't had this camera that long.
  • rammy_srk Mar 14, 2009
    my cam also has the same problem and HP refused to service it....
    http://srkblogs.blogspot.com/2008/11/wha...****-is-hp-support-doing.html
    HP played dirty by offering me printers at a discount in exchange of the camera......HP expects me to spend on the printer whereas what i want is a service for my cam.....
    http://srkblogs.blogspot.com/search/labe...
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
How to fix an error 99 on a Sigma 24-70 mm lens
The error 99 on your Canon is the last thing the camera can think of, if it really does not know what is wrong.
If you don't have the message when using a different lens, and the error keeps coming back with that lens, you are right it is in the lens. But again the camera can;t find out what.
The only thing you can do is make sure the contacts are clean and shiny and nothing os blocking free movement of all the parts on the lens. If you can't get it working correct, please contact a Certified Sigma service centre.
Apr 28, 2014 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
Hi there I have recntly purchased a Canon 15m EF fish eye lense which I have used on a Canon 450d + 350d body. On the 350d I get an error 99 code and on the 450d get a 01 error code. This leads me...
Rob, Error 99 is Canon's catch all error code, yes my first impression would also have been to clean the contacts but something else that is happening is the camera firmware may need to be updated to handle that particular lens. Camera updates are free on the Canon site and actually can solve a lot of hidden processing problems.
That lens isn't really suitable for your 450d as it's an APS-C sensor size with a 1.6 crop focal factor which will give you more like a 24mm focal length.
You may also want to format the memory card and clean your battery terminals both the battery and the contacts in the battery compartment.
Best little cleaning item for cleaning contacts is a pencil eraser (new) lens contacts or battery something about the soft rubber cleaning off the most suborn dirt and electrolysis.
Don't use a "used" eraser obviously it will transfer the dirt to the contacts over removing what you want.
Hope these techniques work they have for me
Feb 21, 2011 | Canon 15mm f/2.8 FD Lens
M547 camera lens will not open
My son has this camera and dropped in the sand this summer. He had the same problem.
I found this blog posting.
Read it. And try all the techniques.
I took the camera to our photo printing store and the guy sprayed it with compressed air. It didn't do the trick but I think it helped. We tried all the techniques in the article. In the end I put some WD-40 in a dish and used a toothpick to drip the WD-40 into the space between the lens barrel and the camera case. I powered on the camera while my son pulled on the lens. He pushed back the flaps and pulled from them. Somehow, after several tries - and I was ready to give up - the lens opened. We still got a lens error message. We kept brushing away and blowing out sand and turning the camera on and off. Eventually it started working. However, the zoom is not working. But we are going to go back to the photo store and have him blow more air into the lens.
Good luck. Hope this isn't too late and helps you.
Aug 10, 2008 | HP Photosmart M547 Digital Camera
Canon D40 Error code 99 keeps coming up no matter what i do
Unfortunately, the ERR99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is going to be very difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to return the camera to Canon for a warranty repair, however if it is brand new, I would take it back to the store for an exchange.
Hope this helps,
Matt
Apr 21, 2008 | Cameras
Lens Error
HI MY CAMARA IS TURNING ON EJECTING LENS THEN IT GOES BACK IN RE SPITS LENS OUT THEN COMES UP WITH THE LENSE ERROR I HAVE PUT NEW BATTERIES IN REMOVED THE CARD BUT STILL NO JOY WHAT DO I NEED TO DO.
THANKYOU
JULIE
Feb 22, 2008 | HP Photosmart M525 Digital Camera
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Error 18
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 18
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 18
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
HP Photosmart MZ67 Digital Camera Logo
275 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
