Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Cannot get wireless connection through router
Hi. I've had this Netgear router for almost 3 weeks now. When I got it, I installed it and set up my secure wireless network and everything worked fine until a few days ago. Now, everytime I try to connect to my network it tells me the network security key is incorrect. This is the passphrase that I set up or no?? It's not the internet connection because I connect through ethernet directly to laptop. And the laptop connects to other unsecure networks, so it's not the computer. When I try to get on the login site for netgear to check my settings, it locks up "thinking" & times out. ?? Anyway. Can someone help please??? I've tried everything I can think of.
  • jnhester Aug 20, 2008
    Hi! I've had my wireless router for about 3 years now. I am moving and unfortunately I lost my box and directions and I do not remember how to install it. I've tried plugging it in and that worked but it asks for an encryption key and I do not know what that is. I remember it from the first time I installed but like I said, that was 3 years ago. Can anybody help me?
    Novelist:
  • 173 Answers
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Posted on Jul 28, 2008
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I am trying to connect my ipod touch 8g to netgear router and i forgot my password
In order to find the wireless security password of your Netgear wireless router , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.1.1 and hit enter.
2. You will be logged into the Netgear router setup page .
3. Under the wireless settings you will find the security password for your wireless router.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Dec 31, 2010 | NetGear DG834G Router
Connected up the router replacing my Netgear 614 and wireless connections says can't connect to wireless network, this was a used working router, I do not have the original installation CD if i need to do...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Jun 24, 2010 | NetGear RangeMax WPN824 Router
Afriend gave me a Netgear Rangemax wireless router I don't have the instillation cd and I've never installed one could you help? I'm connected to qwest broadband and I have a Dell pc. My son just got the...
If you are connecting to the wireless router using LAN cables only then you can ignore the wireless setup part.
To configure Netgear wireless router and the wireless cards in the laptop and PC follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL : -
http://192.168.0.1
3. Enter the router setup, login and password : -
Login = admin
PW = password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
3. Enter the router setup login and password
6. Setup encryption key the strongest is WAP2
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Connecting Netgear Wireless Router to @Wire Wireless Router
You don't need to connect your netgear, you have only to connect your computer to the 2Wire (is wireless also) - If your computer ins not wireless Only you have to do is insert a wireless PCI card in your computer or and USB wireless device and connect to the 2Wire Wireless Router
Feb 11, 2009 | 2wire HomePortal® 1800HW Router...
CONFIG. NETGEAR ROUTER
did you install the modem software and the router software? you may also want to use the network wizard to see what it tells you. are you wired or wireless at the pc? if a laptop, did you install the wireless connection (either a usb or internal)?
here is how to set up the network. netgear is the same way.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Oct 20, 2008 | NetGear WGT624 Wireless Router
Wireless INstallation
you need to ring your ISP to get a network user ID and password, when you enter these in to the router settings the Internet light will light up green.
Jun 08, 2008 | NetGear DG834G Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
173 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
